Bottom Door Hinge
davidlive
Member
Nov 19, 2011
216
27
18
Simi Valley, California
I need to do a lower hinge repair on my 1978 coach i recently got, and the bracket part that held it is complely broke out, does anyone have the
dimensions where to drill the holes for the bolts to go though the other side, (otherwise i'll just line up the hinge to the wear marks and use that)
Thanks David
1974 G-M-C Painted Desert #136
"Oversteer is when you hit the wall with the rear of the car, understeer is when you hit the wall with the front of the car. Hp is how fast you hit
the wall, and torque is how far you take the wall with you when you hit it."
David,
I read a measurement from center of top hinge lower bolt to center of top bolt on lower hinge
of 38-5/8 inches.
Between hinges is 37-3/8 inches.
PO damaged the lower hinge on my coach, but not that severely. Just deformed.
Good luck on the repair.
”When we avoid the mistakes we might have made, we sometimes make the mistakes that we might have avoided.”
Adrien & Jenny Genesoto
75 Glenbrook 26-3
Yuba City,Ca. Text 530-nine-3-three-3-nine-nine-6
