Check the small vacuum host to see if it goes to a vacuum reserviour that is
about the size of an orange on the drivers side firewall. I suspect that this
is the vacuum source going to the heater/ac control head. If you are not
getting correct vent switching with this hose off, then you found it!
To repair, I bought a section of standard vacuum hose, since mine had adapters
on the ends (from GMC) to get the small stuff on a larger fitting. I just
went with the stuff that fit the fitting outright, and is more durable to boot.
- - Tim
> Thanks Emery I think I got the fluid vomiting under control.
> I installed the new radiator cap. I am not losing fluid any longer (at
> least I didn't on my test run). The cap I put on was a 10lb, that's all
> they had on hand at Napa.
> I also installed the new temp. sender.
> I noticed a couple of things while doing this.
> (1) there is a small black hose (maybe 1/8" diameter) that goes to a "T" on
> the intake manifold near the rear of the carb. This comes from somewhere
> near the front of the GMC? I initially thought this was a wire but I cut
> the melted end off and it is a small hose. Anyway, it had melted in half.
> Anyone know what this is and how to repair it.
> (2) A vacum line that runs from the front passenger side of the intake to
> the distributor (I assume to control timing advance) was cracked. I
> corrected this.
> (3) I do not think my fan clutch is working. I don't hear any roar at start
> up or when I am cruising up large hills? I need a replacement but there is
> no local Pep boys to purchase the Hayden 2797 HD. Napa does not have them.
> I'll check the other local stores but does anyone know where I could order
> one?
> Thanks in advance...
> >From: "Emery L. Stora"
> >Reply-To: gmcmotorhome
> >To: gmcmotorhome
> >Subject: Re: GMC: Boil over....
> >Date: Tue, 30 May 2000 16:11:24 -0600
> >>Hey again,
> >>Last fall before we stored our GMC I flushed and filled the radiator
> >>with fresh fluid. I took it for a short drive after doing this and
> >>notices some fluid had been ejected from the system when I stopped.
> >>I didn't think much of it until yesterday. When I drove the GMC
> >>home from storage a noticed the "Engine Water" dash light. I added
> >>fluid when I got home and the light went out. Later we took another
> >>short trip (10-20 miles) and when we got home again some fluid was
> >>released from the system, I am guessing it was much less than a
> >>gallon. Later we went for another short trip (ice cream run) and
> >>the "Engine Water" dash light was lit again but it only stayed on
> >>for a few minutes?
> >>The temp gauge for the engine never got much more than a hair above 1/4.
> >>Any clues on this one. I am planning a new radiator cap but have
> >>not located one locally yet.
> >>Thanks in advance.
> >>Chris Taylor
> >>76 PB
> >>Rochester, MN
> >Chris - first, pull out your original temperature sender unit
> >(located on front top drivers side of engine with a single wire
> >cliped to the top). The original sender showed 225 deg at 1/4 and
> >250 deg at 1/2. If it gets to 1/2 you are probably boiling out your
> >coolant. Go to NAPA and buy a TS6469 sender. This will show 1/4 at
> >180 deg and 1/2 at 215 deg. Apparently GM used the wrong sender.
> >Don't know their reasons but for years GMCers have been replacing the
> >original.
> >It sounds as aif you definitely have a leak. You should borrow a
> >radiator pressure tester. I think that AutoZone has them in their
> >group of "loaner" tools. Fill your radiator, put the pressure tester
> >on and pump it up to the level shown for a 9 pound pressure cap.
> >Look at all hoses to make sure that none are dripping. Its not
> >uncommon to find a heater hose, radiator hose or even a small leak
> >from a radiator tube. A small drip will take a pressurized system
> >down a gallon in no time.
> >If you were in NM instead of MN, I'd loan you my tester.
> >Also use this tester to test your radiator cap. If it more than 1 to
> >2 years old it'll be bad and not hold pressure.
> >Replace it with the original AC/Delco 9 pound cap. Check Gene
> >Fisher's site for the part number.
> >Emery Stora
> >77 Kingsley
> >Santa Fe, NM
> >Emery
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
- - Tim
> corrected this.
> one?
> >To: gmcmotorhome
> >>Hey again,
> >>for a few minutes?
> >>Thanks in advance.
> >>Chris Taylor
> >>76 PB
> >>Rochester, MN
> >original.
> >Emery Stora
> >77 Kingsley
> >Santa Fe, NM
> >Emery
