Bogie straightening
hal stclair
923
It looks like I've got a left center bogie a bit out of shape. I've looked at the tool for bending the arm by pushing on the frame/bogie box but that
method has been used on non reaction arm coaches. Anyone have any experience doing a reaction arm equipped rig? I'd hate to think it would be
necessary to R&R everything each time I did a bend. Any thoughts?
thanks, Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
> that method has been used on non reaction arm coaches. Anyone have any experience doing a reaction arm equipped rig? I'd hate to think it would be
> thanks, Hal
Hal,
I think it may matter which arm system you have. Mine are the Kanomata/Pryor version.
I just let the bar down at one end. I think it was the bogie bracket end and set up the Porta-Power. It was simpler and faster then I expected. It
did take three or four pump and release cycles to hit the mark.
Given the relative sizes of the bogie arm and reaction arm, you could probably bend the bogie the necessary amount without an great concern, but if
you take Matt C's route you'd be safe anyhow. The reaction bars have enough side play to let the bogie be way out of alignment without binding.
Hal,
I suppose you're concerned, as I would be, about using the back of the
reaction arm's torque box as a bearing point for the forcing tool between
it and the frame. As a not-too-expensive alternative, you might consider
the Alex Sirum method: a long pipe (2"-3" OD) welded to an old steel
wheel. With the wheel mounted and the suspension arm supported, he (with
help) is reportedly able to move the bogie arm to any desired position.
I've never even seen it in person but it sounds reasonable.
On Mon, Mar 4, 2019 at 8:43 AM Hal StClair via Gmclist <
> but that
> thanks, Hal
> 1977 Royale 101348,
> Rio Rancho, NM
I have Manny's system and as Ken suggests, I hesitate to place the load on the torque box. The method you suggest Ken, would put an awful load on the
bearings if I understand what you are saying. But then again, I guess the bearings are subjected to some pretty nasty loads just making sharp turns.
I'll have to re-evaluate my options when I get into it I guess. Just returned from almost 3 months in the coach Saturday PM so have lots of catching
up to do on the home front.
Thanks, Hal
1977 Royale 101348,
Rio Rancho, NM
Hal the bogie pusher I have pushes on the arm and not the box.
http://www.gmcmhphotos.com/photos/member-galleries/p66047-bogie-pusher.html
http://www.gmcmhphotos.com/photos/member-galleries/p66048-bogie-pusher-in-use.html
> the bearings if I understand what you are saying. But then again, I guess the bearings are subjected to some pretty nasty loads just making sharp
> turns. I'll have to re-evaluate my options when I get into it I guess. Just returned from almost 3 months in the coach Saturday PM so have lots of
> catching up to do on the home front.
> Thanks, Hal
C. Boyd
76 Crestmont
East Tennessee
Chuck,
I tried that pusher and wasn't able to tighten it enough to get the bogie to bend and stay. Too old and decrepit I think. I ended up renting a
hydraulic pusher kit and fixed a laser to the wheel with my wooden version of the Work alignment kit and a target at the front ride height slot
location. Put a line on the target where the frame-to-laser distances were equal and went a little at at time. With the laser setup you can move it a
little at a time and see how much overstretch you need. Agree that pushing at the end of the bogie arm makes the most sense.
Bill Van Vlack
November 2015.
Bill, there is a method to straightening or bending bogie arms. It takes a
minimum force of 10,000 pounds to bend the ones I have done.
On Mon, Mar 4, 2019, 9:27 AM Bill Van Vlack via Gmclist <
> Chuck,
> Bill Van Vlack
> mid
> November 2015.
Is that a 21-foot long pipe?
On Mon, Mar 4, 2019 at 10:21 AM Ken Henderson via Gmclist <
> Hal,
> Ken H.
> > but that
> be
> > thanks, Hal
> > 1977 Royale 101348,
> > Rio Rancho, NM
*John Phillips*
I don’t remember for sure but I think it was 10 foot.
>> Hal,
>> Ken H.
>>> but that
>> be
>>> thanks, Hal
>>> 1977 Royale 101348,
>>> Rio Rancho, NM
>>> GMCnet mailing list
> *John Phillips*
I thought that I had pictures of the device, but alas no. It was a 2” sched 40 pipe 10 foot long welded to a old rim center section so that it could bolt up to the axle hub that needed to be tweaked. You can contact Jim Bounds at The CO-OP at 407 857-5777 or email coopmotorworks He might sill have the pictures archived.
J. R. Wright
GMC Great Laker
GMC Eastern States
GMCMI
78 Buskirk; Stretch
75 Avion
Michigan
On Location in Tucson
I believe that it was Alex Sirum GMC that came up with this several years ago.
You might check with Jeff Sirum.
> J. R. Wright
> GMC Great Laker
> GMC Eastern States
> GMCMI
> 78 Buskirk; Stretch
> 75 Avion
> Michigan
Emery,
Sirum has tweaked the system he uses to straighten the bogies. He now uses a 4' by 4" diameter steel pipe welded to the steel rim, with some
additional steel gusseting where it attaches to the rim. To straighten the bogey he hooks a come along to the end of the pipe and the other end hooks
underneath to the chassis at a crossmember. Depending on where the attachment point at the chassis is located, forward or aft, the bogey can be bent
either inwards or outwards. This allows one person to straighten the bogey using mechanical advantage instead of body weight and muscular strength.
It's also more precise an application of force.
As a point of discussion, I have never heard mention of concern for bogey bearings from an impact, only concern about load on the bearings when
straightening the bogies. I'm of the opinion that the initial impact that bent the bogey in the first place, in an uncontrolled fashion, would put
more load on the bearings then straightening the bogey in a controlled fashion.
If there's no mention of inspecting bearings when straightening a bogey, at least in my experience and readings, is this really such a concern?
RV
PS Chuck, that's a really nice little bogey straightener. 😉
'77 Birchaven TZE...777
Jim H,
I was able to successfully straighten my bogie arm using the method I described, i.e., a Porta-power against the frame at the end of the arm. Aside
from the wheel/lever arm method and the tool posted earlier, that was the only method I found.
Bill Van Vlack
November 2015.
Hey, that's an even better idea, Chuck, when only toe needs adjustment.
I'd thought about something like that, but didn't know it was really
feasible.
On Mon, Mar 4, 2019 at 12:07 PM Charles Boyd via Gmclist <
> sharp
> > Thanks, Hal
> C. Boyd
> 76 Crestmont
> East Tennessee
Thanks for the tip Richard. I built one using an old steel rim with a 54" 2x4 tube welded perpendicular to the rim. It seems to work almost too well
although it's a bit of a chore to hit the pull just right.
Hal
1977 Royale 101348,
Rio Rancho, NM
I use a porta-power and a short ram cylinder with a shop made fixture that
centers up on the back of the bogie spindle. I set up a dial indicator on a
heavy jack stand to measure the amount of travel. Very precise. No
overbending.
Dick Paterson has a similar fixture that uses a 1" diameter threaded
fastener to provide the force. I used his when we were in Canada and a
coach needed some straightening. It works well. Many ways available to
skin that cat.
78 GMC ROYALE 403
On Thu, Mar 7, 2019, 8:44 AM Hal StClair via Gmclist <
> Hal
> 1977 Royale 101348,
> Rio Rancho, NM
