If memory serves me I believe that those systems ran at 20 psi. They would have intank pumps.
Get Outlook for iOS
https://aka.ms/o0ukef
Sent: Monday, July 31, 2023 5:35:31 PM
To: gmcmh-efi
Subject: Re: [GMCMH-EFI] Blowing Mufflers
Several GMC owners here in the Northwest have home brewed efi systems using the GM throttle bodies and 7747 computers. Various 02 sensors and ignitions. Most work well with minimal "twiddling" with BIN files. Most are not very complex.
Opps, my bad, its Keith Vasilakes who I believe has a GM based EFI system with the higher pressure Rochester TB.
-------- Forwarded Message --------
Date: Mon, 31 Jul 2023 16:39:39 -0400
To: GMC Motorhome EFI Group
There was a GM throttle body EFI system used in 94 or 95 that used smaller injectors at about 30 psi. I believe that is what Randy Van Winkle is using and also KevinV (or is Kelvin? Sorry on my cellphone)
Check with them to be sure which system you are using before ordering a new pump.
Bruce Hislop
Thanks to everyone who replied with suggestions! I have considered all of them and am very grateful for your thoughts. With some guidance from Dick Patterson I have installed an all-new ignition system. ATM I am addressing the fuel system which I think delivers way to much pressure for my throttle body (rated for 30) psi. I am boiling my gas and processing copious amounts of fuel through my system, most of which is returned to the tank. The current pump easily puts out 100 PSI and I believe it is overpowering the built in regulator. I would like to know what external fuel pump/filter others are running and hoping to drop the pressure significantly. This is a modified TB from a '95. I think a 50 psi output would supply plenty of fuel given these were originally using 9 - 11 psi.
If you are blowing mufflers up, you have unturned fuel in them. That should NEVER happen, no matter if you have a Carburetor, or anyone's fuel injection. That is unburned fuel passing completely through the engine. Because you stated that you have had it more than once, I would look first at your O2 sensor placement. Then, fuel/air ratios. That should give you a place to start.
Hello friends, my first time posting here. Some of you may know me on FB as Dave Gee.
I have made every mistake possible in trying to convert to EFI on my GMC coach. I am now on my 3rd TB and am still exploding mufflers. The coach seems to run well enough but I have now destroyed 4 mufflers. I started with the Holley Quadrajet and Hyperspark. After multiple hardware failures I decided to try AFI's GM TBI system for a mid 90's truck. It runs very well but has blown up mufflers. I may have fixed the problem by installing a new retrofitted HEI with computer control. The old distributor was in pretty bad shape despite the engine running well. I also switched from E3 plugs to NGK Iridium. Since I am not sure the problem is solved I want to do further diagnostics and have purchased an AEM wideband sensor/gauge set and also purchased the ALDL to USB cable for use with Tunerpro.
I am trying to find the files to load for a $31 mask as well as a concise tutorial for using Tunerpro. It seems that every site I have looked at was either gone or no longer administrated.
I know I should have started here first. Bill Van Vlack and others were kind enough to reach out to me a long time ago before I went with Holley. What a mistake that was!
Any guidance and links to the resources I need are appreciated! Thank you!
gmcmh-efi+...
