blow outs with E rated tires
thomas g. warner
1,863
" 'E' rated tires will increase the margin for error, but they will not end
all tire failure". OK has anyone ever had a blow out with a E rated all
steel tire?
>> -----Original Message-----
>> From: owner-gmcmotorhome
>> [mailto:owner-gmcmotorhome]On Behalf Of Dave
>> Sent: Tuesday, May 18, 1999 9:32 AM
>> To: gmcmotorhome
>> Subject: RE: GMC: what has a person got to do to explain the obvious?
>>I am using the 8.75R16.5 XPS-RIB load range E Michilan's (4 ply
>> steel tread /1 ply steel sidewall) inflated to 65psi.
>> The thing I don't understand about this whole discussion is why would
>> anyone want to use a D rated tire. Its clear from the discussion, the
>> recall, the various articles and my personal experience that there is a
>> potential problem with using D rated tires. So why take the risk?
>> My thought is that tires are no place to be pinching pennies. I always buy
>> premium quality tires. I have never had a tire failure on any of the
>> premium tires that I have used over the years. I always wear them out. The
>> fact that they usually last longer helps offset some of the extra expense.
>> But no matter how you look at it, good tires are cheap insurance...
>> Dave
>> 73 Sequoia
>Dave, I agree with you completely about not wanting to take a risk on 'D'
>rated tires, when 'E' rated tires are specified. However, I have been a GMC
>owner for 17 years, and I somehow missed the 'D' recall. Therefore, I have
>always replaced my tires with the ones listed in the owner's manual, and I
>have never had a failure.
>This doesn't mean that I endorse 'D' rated tires in our application, and I
>will replace mine with 'E' rated tires when replacement is necessary. But I
>don't think 'D' rated tires represent a "crisis" that needs to be remedied
>at any cost. Motorhomes are large vehicles that place large demands upon
>their tires. Proper maintenance of these tires, especially inflation
>pressures, alignment, and loading are important. 'E' rated tires will
>increase the margin for error, but they will not end all tire failure.
>Scott Shean
>78 Royale
>Baton Rouge, LA
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
> steel tire?
IIRC, that's exactly what Dave Greenberg experienced on the way to
Marion, NC last fall. Bridgestone replaced the tire and paid for the
repairs to Dave's coach.
Patrick
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
I don/t believe that Daves are all steel tires.
>> steel tire?
>Patrick
>Patrick Flowers
>Mailto:patrick
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
They are now - see the following:
> Date: Fri, 14 May 1999 15:47:29 -0700
> From: david l greenberg
> Subject: Re: GMC: Tires (again)
> Are you having trouble keeping up with me, Paul? I turned in my R265
> LRE Poly/Steel after 4 1/2 faithful years and 45k miles. The new
> Bridgestones (I foget the designation) are steel belted side walls in
> LRE. They gotta be 50% heavier than the R265s.
Dave will have to tell us whether the failure was before or after the
swap. You listening Dave?
Patrick
Patrick Flowers
Mailto:patrick
> > The new
And also the designation and size please.
I started hunting locally yesterday and was told no All Steel Bridgestone in
16"
First I have to deal with my Alcoas' -- recall candidates :-(
Heinz
Tom:
I have.
Paul Bartz
Sent: Thursday, May 20, 1999 7:58 AM
Subject: RE: GMC: blow outs with E rated tires
steel tire?
On Thu, 20 May 1999 08:41:31 -0400 Patrick Flowers
>not end
>all
>> steel tire?
>Patrick
Not exactly, Patrick......the tires on the coach at that point in time
were D rated poly/steel Bridgestones.
The old girl now sports E rated all-steel Bridgestones. I use 225 75
R16's which I bought from Alex Sirum. They are so heavy and solid that he
and I are of the belief that they will run flat with no trouble! [g] In
fact he can't use a regular tire mount-dismount machine. Someone said
their dealer said there is no Bridgestone 16" all steel. Translated it
means he didn't have them in stock and didn't want to order them.
For price comparisons call or write "The Tire Rack"..they advertise in
the car magazines. I bought my first set of B.S. tires from them and they
shipped directly from B.D.'s warehouse. Whatever you do, when buying
tires insist on checking the date codes to make sure they are fresh. The
two tires I had to buy after the blowout on the way to Marion were 2
years old!
BTW, my new Alcoas arrived at Sirum's Wednesday. Alcoa air freighted them
out as they knew we were leaving town next week.
Now I can worry about other things!
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
