Evening all,
Finally decided to replace the black tank on my 74 Canyonlands, I suspected it had problems so the other day I filled it up to just where the shower
drain was going to overflow and went outside and could see Niagra Falls running off the top. I know it could be just seals at the bath hook up but
think it's time, with the mess of Silicone that has been put on the first valve, worried that the next time I have to close that one to work on the
Macerator its going to start leaking and the one behind the tee is just about completely frozen to the point I don't think I could dump it with stinky
slinky if I had to. I have searched in all the photo files and through the forum search and have not found a really concise description on to exactly
go about it, just bits and pieces and how to handle common issues no step by step. If anyone knows of a paper or presentation that is out there or
have any hints I'd really like to hear about them. Located tanks at Sirrums in Okeechobee and they are drilled or undrilled, that's a good question.
Another question would be to get to the rear sink and shower connector on the back of the tank do you go at through the area in front of the water
tank? What other parts and pieces will be needed to get this accomplished, replacing both valves is a given. Any and all ideals will be welcome.
Thanks.
Skip Hartline
74 Canyon Lands, FiTech,
3.7 FD, Manny Tranny,
Springfield Distributor,
2001 Chevy Tracker Ragtop Towd
Thanks.
Skip Hartline
