Better MPG with gear change - WHY ?
dave silva
1,090
I've seen it said here many times that folks claimed better MPG after switching to a higher final drive ratio.
Also in my Ford Excursion groups, many people claim better MPG after going from 3.73 to 4.10
BUt i know a few car engineers and they are pretty smart guys so when something beats OEM design I am always suspicious.
In the case of the Excursion, it's often related to compensating for larger tires.
Are there other explanations?
Dave & Ellen Silva
1972 Revcon Olds 455, toro drive train. All Stock
Basically, in a nutshell, puts the engine rpm verses power in a more useable spot in relation to speed.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Dave,
The GMC motorhome final drive was a compromise at it was the best that MG had on hand.
The 403 and 455 are really not in a useful power band until the motors are up in rpm say in 2700 to 2800 rpm. As hot rodder say it gets up on the cam!
403 = Big bore and short stroke The motor likes rpm. Our first coach was a 77 with a 403 and it was a real dog in any type of hills and on the flats it never really ran well until over 70 MPH when the rpm was up towards 2700 RPM. Put a Jim K 3.55 final and the coach really woke up and would put the hills with any 455.
Because the engine is now “up on the cam” it is happy and more fuel efficient and not lugging. The 455 is similar but it is a small bore long stroke motor. Mine is a basic explanation and I am sure that Matt C can give you a technical explanation.
Presently run a 3.50 chain drive with a 3.21 final for a 3.66 final ratio and it pulls my 29 1/2’ Buskirk stretch all over the western US. 3.55 and 3.70 gears provide the best service and Jim K thinks that the 3.70 gear is best.
JR Wright
Michigan
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
More vacuum with less load (higher numerical gears) means the primary rods stay pulled in more of the time, metering less fuel. That gives better MPG
even with more combustion events per mile.
I'm sorry.
I did write a page long explanation, but the forum dumped it when I tried to post it. I don't have time to redo now.
