Which is better for filling the GMC cast iron intake manifold crossover, Aluminum or HardBlok?
I've had a recent quote of $100.00 from an aluminum foundry to fill the manifold. I understand it takes about 20 lbs which works out to 3.5 quarts.
Hardblock is $104.00 for their large size, which makes 3 quarts of filler. I would need to buy two of them.
My manifold has a crack, as does another that may be filled at the same time. I will use the Paterson block-off kit as well. (BTW, I've recently seen
a block that had these installed and that had been in service for several years. The kit remained on the block and the SS plates were deformed into a
'hump' in the area of the exhaust ports. Presumably hot enough that exhaust heat sent them into the plastic zone and pressure pushed them in (this
manifold did not have the crossover filled).
Bill Van Vlack
November 2015.
Bill Van Vlack
November 2015.
