I have some down in the shop. I am in the house right now. When I go down
there in a bit, I will get the EXACT part numbers and product codes for you.
On Sat, Apr 25, 2020, 9:22 AM Stu Rasmussen via Gmclist <
> Jim, I'm not finding 3M 5300 sealant - can you check that is the correct
> number? Several other 5300 numbered items but no sealant.
> I'd like to get some based on your experience / recommendation instead
> of making my own mistakes.
> Thanks!
> Stu
> > Just one more thing that I thought of:
> > The moulding that joins the ROOF AND SIDES TOGETHER has removable end
> > seals? on the fore and aft ends of the mouldings. They have a custom made
> > rubber or neoprene piece inside that is supposed to seal the ends of the
> > extrusion. They are 40 + years old, not bad for humans, but way, way, old
> > for rubber parts. My coach leaked there on all 4 corners, but the drip
> rail
> > moulding did not leak along the entire length of the coach. Under those
> > drip rails, the factory used a black, NASTY, non hardening, gooey
> > substance that really works well. But, the end pieces are the weak link
> in
> > the chain. I removed the end covers and resealed them in a bed of 3M 5300
> > non-hardening flexible sealant, black in color. It is almost as nasty to
> > work with as what the factory used under the drip rails. But, it did the
> > trick for me.
> > Jim Hupy
> > Salem, Oregon
> > On Sat, Apr 25, 2020, 7:53 AM Charles Boyd via Gmclist <
> >> Sir, I believe that belt line piece is 2 pieces. It is a body line
> >> junction for the aluminum and the SMC till it gets to the front cap
> which
> >> is all
> >> SMC. There is an added piece of aluminum that extends the 2” wide joint
> >> and is removable by drilling out the rivets. Your leak is probably at
> the
> >> joint.
> >>> Just a quick update. I pulled the belt line molding off, got in the the
> >> crack on the extrusion with a brush and a pick ) which I later switched
> >>> out for an exacto knife) and dug out as much crud as I could. Most
> spots
> >> were tight to the body so not much to get out. The spots where it had
> >>> separated a bit I was able to get out a bit more. I then used a nylon
> >> brush and some alcohol and scrubbed in the crack as best as I could
> while
> >>> wiping it down with a rag. It was as clean as I could get it. I taped
> it
> >> off leaving a spot for about a 1/16" bead of sealant. I used RTV. Ran my
> >>> finger along the bead to push into the crack as best as i could and
> >> removed the tape. Job done.
> >>> I woke up to a heavy rain this morning and excited to see the fruits of
> >> my labour, I poured a coffee and headed out with a flashlight. Now. The
> >>> big question. Did it work??? Drum roll please!!!!...
> >>> NO! Well sort of...
> >>> It did limit the amount of water getting in and targeted the
> culprit(s).
> >> My coach is on a sloped driveway, nose down, so the gutters have all the
> >>> water coming out the front end. That stream is permeating at the body
> >> seem behind the fender and beside but below the window on both sides.
> Right
> >> at
> >>> the belt line. It's not coming from any higher. It's right at that
> >> joint.I had previously sealed those seam lines and cut out about a 1/4"
> to
> >>> accommodate the new sealant. I suspect there is a gap between the 2
> >> sealants where water is still getting in. I now know what I have to do.
> Just
> >>> have to wait for the rain to stop here in Vancouver which can take some
> >> time.
> >>> Anyway, I guess I'm back inside the coach until the rain stops. Much to
> >> do in there as well.
> >>> Shawn
> >> C. Boyd
> >> 76 Crestmont
> >> East Tennessee
> >> GMCnet mailing list
