Belated trip report
gordon gibson
109
Belated Trip Report
First trip of any significance (i.e. over 500 miles) with my coach - a 1976 23" Norris Upfit with "new everything" (frame, motor, tranny, Honda
EV6010, fitech, etc. etc.). Montreal to Elkhart IN for the GMCMI rally (could be the subject of a long post in itself), across Illinois, Wisconsin,
Minnesota, North Dakota, Montana and up to Calgary Alberta, where I picked my wife up at the airport, then north to Jasper to visit my son who was
working there. Back to Montreal through Edmonton AB, Manitoba and Ontario. All in all, 10,000 kilometers (6,000 miles) in just under 30 days.
Temperatures ranging from the 80s in Illinois and Indiana to a few nights of-10 C (14 F) in Jasper. Thankfully we had good sleeping bags!
I wish I could say the trip was completely problem free, but.....then it wouldn't be a GMC would it? But by and large, things went very smoothly. I
did need a tow in southern Minnesota a stuck thermostat after gassing up resulted in most of the coolant spewing out 5 miles down the road. Good Sam
told me that since it was after 8 PM the best they could do was tow me to the next rest stop then I would have had to start the process over the next
day - guess which membership I am not renewing next year! Luckily a friendly state trooper gave me the name of a local towing company that came
quickly with a truck that was borderline too small (a bit scary but we only had 6 miles on back roads to go) and dropped me at a small garage total
cost $120 ($60 for the tow, $60 for the thermostat and coolant). In Northern Alberta, I started getting some hesitation just after refueling, but I
was really filling to the brim because service stations were few and far between. Once I stopped doing this, the hesitation disappeared. Other than
that, some bearing noise that that surfaced in Minot ND and was with me for the rest of the trip, which turned out to be the differential the only
component that didn't get rebuilt in the initial restoration process. Those big bearings are expensive!
Some observations. The engine that Frank Borrmann built (Borrmann's Garage, Bluevale Ontario) an like a top less than a quart of oil burnt in
10,000 KM. The MAC dash looks great (I have the big one the NGMC), but driving with hands at 10 and 2 mean that both the oil pressure and water
temperature gauges are obscured, as well as a few other less important ones not great for the regular scan. Good thing I was using the Fitech
monitoring panel which allowed me to catch thermostat problem in time and not lunch the motor. I will be giving some thought to this over the winter
perhaps a digi-panel, perhaps relocating a few critical gauges and replacing them with ones that also have an alarm function.
Then finally there's the question of heat. I found that even though the AC on this coach apparently works very well compared to its peers,
temperatures in the mid 80s are about as high as I can bear and still drive with a smile on my face. I know many will recommend it, but tooling down
the pike with the genny running to power the roof AC is not something I want to do. My question is: how effective is window tinting at mitigating
the "goldfish bowl" effect in the cockpit? Having been back from the trip for almost 2 months now, the itch of Tucson AZ in April is something I am
thinking of scratching, but I'll admit that the desert has me a bit scared.
Finally, Jasper Alberta is spectacular. Jasper National park is a 10,500 sq. km. area where development is carefully controlled to preserve the
stunning beauty of the area. Lots of tall snow-capped mountains (at the end of September at least), lots of wildlife (moose, elk, mountain sheep,
black and grizzly bears and even the odd wolf)...and no McDs encroaching on the scenic vistas. Go you'll enjoy it!!!
Gordon Gibson
Montreal West, Quebec, Canada
Gordon,
Sounds like you have a very nice coach.
Do you have the curtains behind the driver and passengers seat that you close to trap the cool AC air in the cockpit?
If not, they are a must.
Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi.
Houston, Texas
sounds like a good trip!
As for keeping it cool in the cockpit, it's a bear!
A good working AC helps but will never be enough in any real heat.
We took about the same length trip this summer and it was brutal when it was 100+ outside.
We just ran the generator and the front AC kept us nice and cool. Gas mileage suffers a bit but 100% worth it.
Out of curiosity what's your aversion to running the genset?
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
My son in law was telling me about a ceramic window tint that blocks UV rays and keeps the inside of his friends' Jeeps much cooler. Like the GMC,
the Jeep Wranglers tend to have a lot of glass, so I'm thinking something like this might help. I don't know the name of the specific product, but I
could probably find out.
Living in Tucson, and using the GMC in all kinds of, mostly warm, weather, we run the generator (Onan Power Drawer) and the roof air while driving
quite frequently without issue. Other than isolating the front cab area with a curtain, that is the only way to keep cool in the Summer. A few
Summers ago, we took a trip to the North Rim of the Grand Canyon and ran the generator/roof air almost the entire time. We always do that on our
Summer trips and generally in the late Spring and Early Fall as well.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Justin - Guess I'm a bit "old school". Running the generator to power the AC may be something I will grow to accept over time, but for the moment, I
like to be able to monitor things just in case there is a problem. With the generator at the back of the coach I would never hear if something went
wrong in time to stop the thing before serious damage happened. I also worry a little about a fuel hose splitting and fire breaking out - I wouldn't
be aware of it till the rear of the coach was engulfed in flames. For the same reason I would never run the generator overnight while sleeping, but
since I am in the north this hasn't been a problem. Just paranoid perhaps.
Scott - it was a pleasure meeting you at Elkhart - we folded laundry together the last night. The curtain sounds like an option although I do use
the rear view mirror from time to time to determine with certainty when I can pull back in after passing.
I usually have the shades on the side windows down and the windows cracked a little while driving on sunny days, and was wondering whether a moderate
tint to the front windows might help. I'm also following the current Bounds series of daily posts on AC with interest. I know Applied GMC sells an
add-on AC unit. Does anyone have experience with these?
Gordon Gibson
Gordon, it's all coming back to me now!
The trip to the laundry room did get me out of the dog house and put me back in good standing!!
And it was a pleasure talking with you.
BTW, I have the foil/insulation from Home Depot. I have cut it to fit and placed it against the window above the drivers side couch and both rear bed
side windows. I keep the drapes closed on those windows so I don't have to look at the silver insulation. And that is a big improvement in the Texas
summers.
Scott
Scott Nutter
Houston, Texas
> bed side windows. I keep the drapes closed on those windows so I don't have to look at the silver insulation. And that is a big improvement in the
> Texas summers.
> Scott
Yes, I do the same thing. It also helps keep the warmth in on cold winter nights while dry camping.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I also use the jumbo car window shades (the ones with the wire sides that are a bear to twist and fold up) to put in my big window over the dinette
and the front windshield at nights.
For me it is easier than trying to finess the original blinds to the down position.
Gordon- if you do decide to go with the curtains, I went inexpensive. I'm using a cloth style shower curtain that is hemmed at the bottom, and I used
fishing line to sew the sliders with. It's very lightweight, but works great.
Scott.
Scott Nutter
Houston, Texas
Consider using clear shower curtains behind the cockpit.
> position.
> great.
> Scott.
> Scott Nutter
> Houston, Texas
