I would buy the Timken bearings from any of the regular sorces as long as
they assured you that they have .0095" of axial clearance. when you receive
them visually check them to ensure that the spacer has that clearance etched
on the bearing spacer provided for the two matched bearings. don't mix
bearing parts or you will be back to square one.Gateway has since raised
their prices from $77 a set to I beleive $80
Cinnabar 1-800-720-2227
Buskirk 1-800-715-1133
Golby 1-800-872-1462
Gateway 1-800-654-0374
Alex sirum 941-763-1121
>Okay, since the matter of the bearings has been settled, for now at least. I
>need to purchase front bearings. SOON!!!
>It was stated by someone that in addition to Cinnabar, Gateway had the same
>bearings with the right clearances and the price for the bearing set WITH the
>seals was $75 as I recall. Where is the right place to buy the right bearings
>at the right price?
>David
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
>at the right price?
>David
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
