>Henry as I am sure you are aware, over 90% of bearing failures are caused by
>seal failure and improper lubricants.
The statistics that I've seen say about 50% to seals and about 50% to
lubricant. Some tend to remove improperly installed bearings from the
dataset, but some studies have indicated up to 30% of failures are due to
incorrectly installed bearings. This is across all types of equipment and
not just automotive. Incorrectly installed bearing failures include over
lubrication (increases rolling resistance) and under lubrication.
None of these statistics have been validated against the GMC front bearing
failure data. Keep in mind that most of the bearing data comes from
industrial installations where they use ferrography or spectroscopy to
monitor changes in the lubrication at regular intervals.
Still, I think that the statistics should be used as a general guide to the
GMC front end.
Timken has a good site for their bearings at at
http://www.timken.com/bearings/fundamen/ They have recently added a page on
visual evaluation of bearing failure. Here's what they say about premature
bearing failures in their experience: "Damage to bearings while handling
before and during installation and damage caused by improper installation,
setting and operating conditions are, by far, the causes of the largest
percentage of premature trouble."
If someone has the time to detmine all of the GMC specific factors, there
is a method of calculating bearing life at
http://www.timken.com/bearings/fundamen/calculate.asp
Here's my proposal to GMC netters:
When you have your front bearings replaced send them to me with a sample of
the lubricant. Let me know miles since they were last changed and front
axle weight if you have it. I'll work with the folks at Timken to build
objective data about "bearing failure" in the GMCs based on physical
evaluation of bearings removed from service.
Henry
Soquel, Ca 95073 / IP reviews
fax: (408) 462-5198
GMC front end.
Henry
fax: (408) 462-5198
