Battery trays
gary miller
452
I installed the Ragusa sliding battery tray which I am quite pleased with and I
think that my satisfaction will continue due to it's rugged and simple design.
I would be concerned about "drawer slides" since they have bearings (the heavy
duty ones which would be required to support the extended loads) which would
soon corrode from the battery acids.
Gary
'77 Kingsley
North Bend, Oregon Coast
> In a message dated 4/27/99 5:11:13 AM Central Daylight Time, HLBF
> > Arch,
> > I know the one you're referring to and that's what kept me from buying
> one
> > at Myrtle Beach - now, where do we get the one with the side slides???
> > Lanier
> Lanier
> I dont know that anybody builds one. It would be easy enough to do.
> Just use heavy duty drawer slides like people use on the under dinette
> drawer.
> Take Care
> Arch 76 GB IL
I made my own battery slide out using two heavy duty, stainless glides
with a capacity of 100 lbs for my two golf cart batterys, and a piece of
3/4" marine plywood. I drilled a hole thru the leading edge of the ply
and thru the floor and drop a large linch pin in to keep the tray from
moving while under way.
Total cost was about $20.....Works for me.
David Lee Greenberg
GMC Motorhome Registry
200 Macfarlane Drive PH 4
Delray Beach, FL 33483-6829
800-827-9989
