Battery Set up?/
doyle todd
22
Could someone tell me how the batteries are set up.
I have two up front and one for the genset.
I assume that one of the batteries up front is for the engine. The other is
for the coach and the one in the Genset compartment is only for the genset.
And when you push the main/boost switch on the dash it connects the two
front batteries together.
Is this correct.
Jack Todd
1977 something. (the only making it has is LPR motor home.)
Jack,
Sounds like yours is a Transmode that was converted by a third party. The
setup you describe was used in the early Motorhomes(73 & 74) and all
Transmodes. Your assessment of the setup is correct. One of the two up
front is the "coach"(engine) battery and the other is the "house" battery.
If you get the GM service manual from Cinnabar, it comes with wiring
diagrams for all three electrical systems(coach, house and 110V).
Patrick
> -----Original Message-----
> From: Doyle Todd [mailto:doyle]
> Sent: Friday, April 16, 1999 9:37 AM
> To: Gmcmotorhome Org (E-mail)
> Subject: GMC: Battery Set up?/
> for the genset.
> connects the two
> Is this correct.
> Jack Todd
Not so fast Patrick. My 78 Royale, started life as a Transmode and has
three batteries up front.
If you really want to be certain of what each battery powers, separately
disconnect each one's negative cable and check.
Paul Bartz
[mailto:Patrick.Flowers]
Sent: Friday, April 16, 1999 9:42 AM
Subject: RE: GMC: Battery Set up?/
Jack,
Is this correct.
Ah yes, but I'll wager that when it left the Pontiac plant headed for
Coachman, it only had two batteries up front.
Patrick
> From: Bartz, Paul [mailto:s9d3452]
> Sent: Friday, April 16, 1999 9:48 AM
> To: 'gmcmotorhome'
> Transmode and has
> separately
> Paul Bartz
> From: Patrick.Flowers
> Jack,
> third party. The
> 74) and all
> the two up
> "house" battery.
> for the genset.
> connects the two
> Is this correct.
Patrick you are right. It is a Transmode
So what about charging????
Does the Genset battery only get charged by the Genset. And is not connected
to others via a charging wire or other?
Jack Todd
1977 something
- -----Original Message-----
[mailto:owner-gmcmotorhome] On Behalf Of
Patrick.Flowers
Sent: Friday, April 16, 1999 8:42 AM
To: gmcmotorhome
Jack,
Patrick
> for the genset.
> connects the two
> Is this correct.
> Jack Todd
If original, the generator battery is only charged by the generator(this
"feature" should be disconnected if you go to a combination house/genset
battery like the later coaches) and the coach battery is only charged by the
engine alternator. The house battery may be charged by either the engine
alternator(thru the diode isolater) or the 12V converter.
Patrick
> Sent: Friday, April 16, 1999 10:04 AM
> To: gmcmotorhome
> is not connected
> Jack Todd
> 1977 something
> From: owner-gmcmotorhome
> Patrick.Flowers
> To: gmcmotorhome
> Jack,
> third party. The
> 74) and all
> the two up
> "house" battery.
> Patrick
> > for the genset.
> > connects the two
> > Is this correct.
> > Jack Todd
And if it is a Transmode setup, you will have a 'Bat Boost' switch that can
be set to the boost position and it will stay there. The non-transmodes
have a spring inside the switch that returns the switch to the normal
setting when you let go.
>Jack,
>Patrick
>> for the genset.
>> connects the two
>> Is this correct.
>> Jack Todd
I thought that was an "Improvement" later in the production run to keep
forgetfull types from running down both batteries(and destroying the low
duty-cycle relay) by leaving it in the "Boost" position. My 73 is a
Motorhome and doesn't have the "monentary" boost switch.
Patrick
> From: Thom Hole [mailto:THHOLE]
> Sent: Friday, April 16, 1999 10:14 AM
> To: gmcmotorhome
> switch that can
> non-transmodes
> >Jack,
> third party. The
> 74) and all
> of the two up
> "house" battery.
> >Patrick
> >> for the genset.
> >> connects the two
> >> Is this correct.
> >> Jack Todd
>that can
>non-transmodes
More or less correct but actually all '73 and early '74 models had a on
or off boost switch. There were no transmodes til '75 and by then all
coaches had the momentary boost switch. Too many early owners forgot to
turn the switches off creating problems.
I believe this to be an accurate characterization of the situation.
Dave Greenberg
