Battery Not Charging
Tom Katzenberger
795
287
63
Happy Thanksgiving to all,
I just installed a Progressive Dynamics converter and my house and coach batteries are not charging. I left the isolator in and installed a combiner.
Just checking to see if anyone may know what I may have overlooked, electric is not my forte.
Thanks all and everyone have a very happy Thanksgiving,
Tom K.
1977 23' Birchaven
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
Jon,
I will be doing that, just thought someone may know the obvious.
I have a multi meter, but I really did like your volt meter and just bought it on amazon based on you recommendation. It looks pretty nifty.
Take care,
Tom K.
I had the exact same issue with my 76 Birchaven 23 footer. In my case it was the circuit breaker. On my circuit breaker the farthest right one has a yellow test switch. It looked to be engaged (on) but when I turned it to off and then back to “on” the battery charger came on. It trips occasionally still. I hope this helps.
James
> 1977 23' Birchaven
Even with no meter you can do the first logical test by confirming 125VAC supply to the converter. Unplug the converter and plug a table lamp or such
into the receptacle to confirm power. If yes the plug converter back into AC and eventually meter output for 13.4-14.2 VDC. With a meter you can also
pull all the fuses in the converter and test for continuity.
John Lebetski
Woodstock, IL
When mine quit charging the culprit was one of the fuses in the converter. Luckily my converter had the fuses with the LED indicators that light if
blown, so it was easy to spot the problem.
Larry
Larry - Victoria BC -
1977 ex-Palm Beach "Ol' Leaky" 40,000 miles, PO said everything working but forgot the word NOT. Atwood helium fridge, water heater & furnace. SS
exhaust system, Onan, Iota Converter, R134A, New fuel lines & heat exchange hoses
