Bath module
bryan strickland
70
I received the bathroom module today. I would like to know what is the
hole for near the toilet? If you were sitting down it is on the right down
low. It is a 4 or 5 inch hole and has four screw holes around it. Plus how
is the shower hooked up to the holding tank? Sinnabar does not show good
detail. I have a hole in the floor for a drain but it does not hook up to
the tank. I thought it was a factory mistake and voided. But it does fall
under the drain for the bath module. I know someone is working on their
bathroom at this time with their smell problem. Hope they can see what I am
talking about.
Any help would be nice.
Bryan with a 26' stripped out
and going together slowly
Is anyone in the Hershey or Lancaster, PA area? I will be in that area
this friday and would like to see your bathroom module. I need to see if
this unit sits on the floor or does it sit up off of the floor. I also need
to see if the drain for the shower is straight into the tank or is it piped
behind the toilet. Please help me with this problem, thanks.
Bryan from N.J.
with a stripped out 26'
Hi Bryan,
I just went out and looked at my 74 Painted
desert. I have the wetbath. There is a hole on the right side of the toilet
off the floor a few
inches. Plumbing for the toilet fill tube comes
in here. This is for charging the toilet. The hole in mine looks about 1.5"
in diamter with
some sealer around it.
Hope this helps.
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of Bryan & Becky
> Sent: Wednesday, July 21, 1999 3:45 PM
> To: GMC Motorhome Digest
> Subject: GMC: Bath module
> right down
> it. Plus how
> see what I am
> talking about.
________________________________________________________
NetZero - We believe in a FREE Internet. Shouldn't you?
Get your FREE Internet Access and Email at
http://www.netzero.net/download/index.html
Thanks, but not that hole. I have a 4 or 5 inch hole with 4 little screw
holes around it . It is near the inlet to the toilet. It could be some
after market fan or what ever. Any help would be nice .
Thanks for your time
Bryan from N.J
Headed to hershey park and hoping that someone is in the Lancaster or
Hershey area so I could look at their coach.
Bryan
The hole is suppose to have an air register over it. It's for heat from
the furnace which is supposed to be ducted from around the rear or over the
top of the coach. It wasn't ever very effective anyway, since it's such a
long run from the furnace. It is a good place for incoming air when you've
got the bathroom vent fan running.
bdub
>Bryan from N.J
If you are talking about the hole on the sidewall next to the base of the
toilet its where the hot air from the furnace comes in. Chuck
> Bryan from N.J
