Bath drain plumbing
james bolick
164
Carpet outside bath gets
soaked, and water leaks from under coach. Water going straight
into drain doesn't leak out -- so piping
Toby, My first experience using the shower in my GMC was just as you
describe. The problem was the seal on the bottom of the door was not doing
its job. Replacing the seal helped me.
Jim Bolick
'73 Painted Desert
Well, with my best Oliver Hardy impersonation voice, "Here's
another fine thing I've got to look into."
Thanks for the tip. I hope there are no hairline cracks in the
fiberglass of the shower pan. Sounds a little 'crunchy' when
stepping in. Sure hope sealing/tightening the drain and (if
necessary) taking care of the door seal cures it.
Toby Maki
73 Glacier 230
> Jim Bolick
> '73 Painted Desert
