Balancing Wheels
phil swanson
660
Now I'm looking for someone in the Atlanta area that uses Hoffman
equipment..............
Patrick, That's just the half of it. I found someone in my area that
had the Hauffman Machine but as the article said, he like others had
never used the Pro Match feature of the machine before. He told me that
it required that they have to install and remove the tire and rotate it
on the rim 4 times to get the optimum placement of the tire to the
wheel. It's allot of labor but you end up getting the tire and wheel
balanced with the least possible weight. He ended up with about half the
normal weight. He didn't charge extra for the Pro Match this first time
on two wheels but he said he would have to charge me $30 extra per wheel
next time because of all the extra labor. Good luck. I am running the
Good Years. My understanding is that the computer on the machine
determines the best placement of the tire on the wheel using each
mounting as a reference point.
Phil
Swanson
