Baja Bound GMCs
david l greenberg
8,798
1
Make sure your fan clutch is working! If you didn't hear it cycle on last
summer (or anytime in Florida!) Check it out. When it cycles on your
first thought is that you accidently pulled the shift lever into low!
Carry a spare ignition module if you have HEI system. Buy only Delco
product. All others are poor knockoffs and aren't worth the aggravation
you will experience.
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
