BAD FRIDGE/FREEZER : HELP
dutch marc
90
Hi Guys, While I am waiting here to get my Radiator replaced, I Just heard from Miguel Mendez that my Fridge is gone.
It used to work fine. I turned it off for cleaning & defrost and now there is this strong ammonia smell coming out of it..
He mentioned time for a new fridge :( Just what I needed when I was planning going on a 4 week trip to CO, Leaving monday ....
My '26" Canyon Land '73 has a Norcold fridge. 2 Door (Fridge/Freezer) that works on 110V - 12V - Propane ...
Does anyone have any Good used Fridge/Freezer unit for sale around So California ? Any suggestions where I can find these guys?
What Brand/Model Specs would work to replace the original '73 Norcold ..
Starting to look on CL but since I am a newby there might be other / better ways to find them .... Not sure what specs etc to look for yet.
Any Help is appreciated !
1973 26' Canyon Land (Mello Yello) (TZE063v101302)
Los Angeles, CA ('98 NL 2 USA)
I don't know what to look for other than a working unit with dimensions the
same as or a hair smaller than what you already have that works on propane
and 12 volt . You could also renovate for a slightly larger one!
You can try salvage yards in your area...if you ask someone will tell you
which one is most likely to have salvaged RV trailers or motorhomes.
Check the model number for safety recall...in might be propane you are
smelling ? Norcold will repair if it is....
Others will have more to say.
Mike in NS
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
I went with a Norcold 641 series. It is about the same size as the original. I think I had to raise the top of the opening 1/2". Dometic makes a
similar sized one.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I had a 641 in the 23' coach. I thought it was broken because it frosted badly, but I found it had aftermarket bins in ther door which kept it from
closing totally. Once I removed them it worked flawlessly, propane, 110 or 12 volts.
Dometic makes a 12/110 compressor model now... its model number is DMC2641RB
Good price
Bill and Mary Kay Boeyen
76 23' Birchaven 455
Tampa, Florida
Only for 19 years. It's my second one. I ignored a recall until it quit,
then they said since the ammonia had already leaked out it was no longer a
hazard, so not covered under the recall. The replacement I bought has been
in service for about 10 years with no further problem. It's rarely turned
off, except to defrost it every couple of years.
> Hi Guys, Thanks for all your input. Have been doing some research.
> Any out here that has a Dometic DMS 2652 installed ??
> https://www.dometic.com/en-us/us/products/food-and-beverage/
> refrigeration/refrigerators/dometic-americana-_-30936
> Any feedback appreciated !
> Thanks Marc
Sent: Tuesday, September 19, 2017 2:34 PM
To: GMC Mail List
Subject: Re: [GMCnet] BAD FRIDGE/FREEZER : HELP
> Thanks Marc
This email has been checked for viruses by AVG.
http://www.avg.com
Hi Ken, Did you mean replaced it with a norcold or replaced it with the Dometic DMS 2652 ??
Thanks
> Ken H.
> > Thanks Marc
Replaced it with the same Dometic 2652 (or maybe 2752?).
> Dometic DMS 2652 ??
> Thanks
> quit,
> a
> been
> turned
> > Ken H.
> > > Thanks Marc
> > > GMCnet mailing list
I have had a 2652mfor about 12 years. I turn it on and it works.
If you were around here I would send you to Leon at National RV refrigeration for a repair or replacement cooling unit. He wil fix the cooling unit
better than new. He is in Shipshewana Indiana. One one of he GMCMI rally repaired.
http://www.fixyourfridge.com/
Let's try this again for the emailers only. I corrected the badly screwed up posting for everyone else but they do not get corrections.
I have had a 2652 for about 12 years. I turn it on and it works.
If you were around here I would send you to Leon at National RV refrigeration for a repair or replacement cooling unit. He will fix the cooling unit
better than new. He is in Shipshewana, Indiana. One of the GMCMI rally attendees if over there right now having his repaired.
