> You can't overfill it. You have an expansion tank that keeps the
> radiator full. When it heats up and the coolant in the radiator
> expands it goes into the plastic bottle. when it cools, it draws
> coolant from the plastic bottle back into the radiator. If it is
> coughing up fluid it is boiling and pushing fluid past the radiator
> cap. Pressure on the system helps keep it from boiling out. Check
> the pressure cap and you'll probably find that it needs replacement.
> They usually only last a year or so.
> Also, don't be lulled into a sense of security that the gauge never
> goes over 1/2. Read my posting from yesterday. You could be at 250
> degrees and boiling over at 1/2 gauge with the original temperature
> sender.
> Make sure that your fan belts are tight. You also might have a bad fan clutch.
> Emery Stora
Emery and who ever else cares to respond,
I have a panel from Custom Instrument Panels and therefore I believe that I have a
reasonably accurate water temp gage. Most of the time it runs at 190 degrees (I
have a 190 degree thermostat) but when I start driving at 65+ the temp will go to
around 200-210 and the oil temp will go from 220 to about 250. I don't like
that! So I usually slow back down to 60 and everything goes back to what seems to
me to be normal.
I wonder if I have a bad fan clutch. I never hear it engage when the temps go up.
How does one tell if they have a bad fan clutch?
Or are my temperatures normal for that operating mode and I should worry more about
the extra gas I'm burning by going faster?
By the way I have close to 140,000 miles on the original engine.
Richard Waters
'76 PB, Troy, MI
> sender.
> Emery Stora
me to be normal.
Richard Waters
'76 PB, Troy, MI
