Back up lights
Ken B
16,833
280
83
I installed a pair of 6 LED 18 watt Cree driving lights on the front of my GMC and loved them. I decided to replace them with a pair of 12 LED 36
watt LEDs. I took the removed 6 LED ones and mounted them on the rear of the GMC to be used as backup lights. (Do not park to close to me or I'll
melt the paint on your vehicle with them.)
The problem I have is accessing the back up light circuit to get power for them. I removed the left rear tail light from the outside and the socket
assembly is riveted in place. Then I looked to the inside for access. I have a permanent bed back there and it will be a big job getting it out to
get access that way.
So I'm looking for ideas on how to get to the back up power wire.
Can you grab the wire midship along the drivers side wall in the cabinet
and go out the floor with it and back?
Sully
77 eleganza 2
Seattle
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
G'day Ken, We mounted reversing LED's under the back of our G.M.C. and used the trailer hitch wiring.
Mark Bennett
Gail & Mark's Cruiser
Gold Coast, Australia.
Motorhoming Lifestyle.com
Ken
Years ago there were UHaul light bulbs..they had a small wire coming out of
the top or the metal where it joins the glass. A 1157 for example would
have 2 wires and was fitted by removing the car tail light lens and putting
in the bulb. The small wire(s) was dangling outside the lens and connected
to the trailer to operate the assorted lights.
If you can find a couple of these, could you drill down and slip a wire out
the bottom somewhere to connect to your lights.
Normal trailer wiring doesn't allow for back up lights so I'm not sure what
Mark did...but check with him first..it would be easier
Mike in NS
On Wed, Oct 19, 2016 at 7:10 PM, Mark Bennett
> Mark Bennett
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
Do it the easy way...get 2 of the little flat panel LED arrays that have the bayonet base for 1156 type bulbs and wires out to the panel. Tap into
those wires with your own and run them to your auxiliary LED lights, and stick the LED panels(double stick foam tape is already on the panels)inside
the back up light part of the taillight. The U-Haul wired lights occurred to me when I read your post this morning, but as Mike said they were for
1157 bulbs. You could use a set of those if you bridge the bulb terminals with solder and grind off the offset lug on the base, but that is really a
gerry-rigged type of solution that doesn't hold the bulb in very well.
These are what I am referring to:
https://www.amazon.com/gp/product/B009E1BW08/ref=pd_sbs_263_2?ie=UTF8&pd_rd_i=B009E1BW08&pd_rd_r=FHGVMXM1RMTVBN4Q9Z37&pd_rd_w=DCOXm&pd_rd_wg=pueq1&psc=1&refRID=FHGVMXM1RMTVBN4Q9Z37
And:
https://www.amazon.com/Light-Motorhome-Dome-Ba15s-Trailer/dp/B00HSHWPXI/ref=sr_1_48?ie=UTF8&qid=1476931276&sr=8-48&keywords=1156+LED
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
And trailer wiring for hydraulic surge brakes will include a reverse power wire to engage the brake bypass solenoid.
Terry Kelpien
73 Glacier 260
Smithfield, Va.
Thanks for all of the neat ideas. I do NOT have back up lights available at my trailer wiring harness. I already checked that. So that way is out.
The Uhaul lights gave em an idea. I'm thinking about removing one of existing back up light bulbs and making an adapter out of an 1156 bulb. I also
think I might have one of those around that is used for some of the flat panel LED lights that I used inside. With either of these I could, as
suggested, drill a small hole and run a wire into the rear of the existing light housing and out the bottom of the coach.
I'm not ignoring the suggestion of finding the wire as it runs along the left side of the coach and tapping into it. That will be Plan B.
Thank you everyone.
JWID - picked up the B/U circuit under the dash. Ran it, and a hot, to a 1P2T center off switch. That is a AUTO-OFF-ON control for the auxilary B/U
light. Ran the wiring out and under the coach in split flex tube. The tube is oversized and filled with extra wires. The extras are used for some
additions and as spares for when I get other wild ideas.
Steve Southworth
Palmyra WI
Ken If you aren't going to use the original backup bulbs I would solder a new pigtail to the center contact in the backup socket. I would then glue a
piece of plastic tubing into the socket to keep the wire from grounding against the socket.
Jim Wagner
Brook Park, oh
76 500GMC
71 355Vega
69 383Vette
> Why go through all the trouble when plugin solutions are out there? Only if you want the fun of doing your own thing. At one time it made sense
> because 1156 LED backup bulbs weren't very bright. Some of those older wimpy bulbs are still out there but now there are lots of very bright
> options as well.
> JP
What are those options?
> glue a piece of plastic tubing into the socket to keep the wire from grounding against the socket.
> Jim Wagner
> Brook Park, oh
> 76 500GMC
> 71 355Vega
> 69 383Vette
I found one already made up for $1.04. I ordered two of them. Using this, rather than soldering will make my changes reversible back to stock.
I would still like to be able to get to the back of the existing socket or the wire running to it, but this will probably work OK.
