Axle shaft seals
alan bredbury
189
Does anyone out there know what the correct part
numbers are for the seals on the inner and outer ends
of the axle shafts for the 455 engine. I can go with
either the actual number on the seal or say a Napa
number? Thanks in advance for the help.
Freezing in Connecticut with engine and drive
disassembled but leaving for Fl in three weeks.
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
Do You Yahoo!?
http://im.yahoo.com
Alan,
Are you referring to the final drive output seals? There are no "seals" on
the axles, unless your referring to the CV joint boots.
Patrick
