Just finished posting both the Radial/non-Radial Wheel and CV Joint
pages on gmcmotorhome.com...
Dave,
You may not be too far off. While going thru the stuff I had written on
the CV joints(I ashamed to say how old it was), I added GM's
instructions on packing the joints. You're supposed to fill the joint
and the folds in the boot - no more. Zeb Frady told me when he sold my
father the outer CV boot kit that it might have three packs of grease
and to use only two. Any more and the joint would leak. The kit did
indeed have three packs of green grease in it, which I promptly threw in
the trash can and used synthetic. Too much grease and the pressure
causes it to squeeze out. I don't really know if grease in the groove
is the problem or a symptom - those that pack in too much grease would
have a tougher time keeping it out of the grooves.
Too much thinking for me tonight. Like Arch, I'm going to bed...
Patrick
> I have never worked on my CV boots so this is only an opinion. It seems that
> when the axle is spinning the weight of the grease would make a lot of
> centrifugal force (centripetal force for the purest) which would push the
> grease to the boot / CV interface. If there was grease under the clamped area
> as Patrick said, the seal would be lost and a path provided for the grease to
> escape. I wonder if a light coating of a tacky material, say like aviation
> gasket sealer, applied to the CV under the boot in the clamped area would be
> acceptable? The coating would have to be very light as you defiantly would
> not want any of this to get into the CV joint. Just a pie in the sky idea.
> Feel free to blast away.
> Dave Meekhof
> 73 GoBus 230
Patrick Flowers
Mailto
atrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
Dave,
Patrick
> Dave Meekhof
> 73 GoBus 230
Patrick Flowers
Mailto
