Be aware that most aluminum used in awnings today and the past is
anodized, but the finish will not last forever. With out the coating
aluminum would corrode very rapidly. Look in the yellow pages in your
phone book or your industrial phone guide. There are several companies
that do this work in detroit area. It is very expensive on a small
volumn basis.
> Clark. Do you know of any companies that do thi work........Frank
> >Date: Thu, 07 Jan 1999 21:37:33 -0500
> >From: searlecj (Clark Searle)
> >To: gmcmotorhome
> >Subject: Re: GMC: Awnings
> >Reply-To: gmcmotorhome
> >> Any suggestions...... The aluminium supports and aluminium awnninig
> >> cover would look much better if it had colour. There is a process
> called
> >> anodizing? Could this be done to the parts.
> >Believe anodizing just gives dull aluminum colored surface. It's
> mainly to
> >stabilize the surface and protect it from corrosion. Probably the
> awning parts
> >are already anodized. Often anodizing is followed with a dichromate
> dip which
> >comes in clear, yellow, red, maybe others.
> >Clark
> >78 Kingsley
> >Mt. Pleasant, Mich (-3 degrees)
> ______________________________________________________
> Get Your Private, Free Email at
http://www.hotmail.com
