from my web page
Pump Second Source
The vacuum pump I used is a complete unit including the pump, vacuum
switch, and resilient
mounting bracket --- everything you need except a filter.
Pump: MP (Master Power) Brakes ---(704)664-8866 Part AC2723
$269.95 plus $20.30 shipping from NC to OR. Mounts easily on the
firewall "box" by the steering post under LH access panel.
Vacuum Filter #675-5136, retail $10.60, Net $7.99. That is a NAPA part
number.
BTW, in the process of checking out my vacuum pump installation I found
that I had a small leak in the original vacuum line to the
booster.....probably never would have found it until complete failure
had I not installed the
pump.Gary
This is available here from the local AC/Delco dealer for around $127..the
pump# is AC215-119
The AC2723 number above is the Master Power number and I had the AC/Delco
dealer xref the
Gm# 22034995.
I found the 4-connection connector at Pep BoysCBWood
gene
>Can someone please post the PN for the Aux Vacuum Pump available from
>Auto Zone IIRC the price was around $125 (?). Tried local AZ and they
>needed a PN. TIA
>Dick Missett
>73
>Wyoming, PA.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
