> Back when we used the original fuel selector valve. And the dash fuel tank selector value switch is in the Aux tank position. That meant that the
> selector valve at the rear was turned on all that time. Not a big deal. But I had the thought that if it's not turned on all the time. Thus since
> it's off. Less is apt to go wrong internally. ( YES. Me being annul over simple things again. ) So I just run on the main tank all the time. And
> when I think I'm in need of around 20 to25 gal. I take a brake to fill up. How with the Howell/GM EFI fuel return. And a pump for each tank. It
> seems that most of that returned fuel. Goes to the rear main tank. I do run the aux tank pump some just to check that it's OK. But then I end up
> filling the main tank up with the return fuel from the EFI. This may help those that live around mountains. Bob Dunahugh
My understanding of the fuel storage system is the fill hoses, which are huge, are mounted a little above the halfway point on both tanks.
if you lose the use of the selector valve, you have access to 75% of your stored fuel given on flat and mild hills.
That would figure fuel access at about 37.5 gallons or 375 miles.
This if figuring 25 gallons of the supply tank plus the top half (12.5 gallons) of the other tank which is still filling the supply tank via the fill
line through gravity.
Sort of sketchy if you are relying on this real time but works by the numbers.
GatsbysCruise. \
Waukegan, Illinois \ Keep those MiniDiscs Spinning \ MY GREYHOUND IS FASTER THAN YOUR HONOR ROLL STUDENT \
WindowsXP-Win7-Win8.1-UBUNTU STUDIO -
