Aqua Magic 3 by Thetford
Mar 25, 2020
108
16
Currently removing /replacing or repair my toilet. It "only" leaks when you
push down on the pedal to let in water so it has to be beyond the valve.
Anyone tackle that job? Looks like it may just be the plastic lines running
to various places that need to be secured with clamps.
Or, what is the suggested replacement given the tight spacing and my desire
to use the same hole?
Dean the resourceful Norse Hanson
75 Avion coming to life.
fremont
Could be the vacuum release on the inside top. There is a rubber grommet that may be bad. Look at the parts manual and you’ll see what I’m talking about.
I just trashed mine as there are no parts for it.
Chaplain Randy Hecht
Roswell, GA
Chaplains are ready to Listen when you're ready to talk.
1974 Canyon Lakes GMC the Unicorn Express
80mm Front Disc and a work in progress
Electric Brake Vacuum System
> fremont
