Look in the back and see if you see a standard House electrictrical plug.
Most refrigerators require a 12 volt to operate the computer that operate
the unit.
Like Carl said, the 12 volt source is not very desirable to use for cooling.
On Sat, Aug 3, 2019 at 7:32 AM Carl Stouffer via Gmclist <
> Depends on the fridge. A three way fridge operates on 12 volts (not as
> efficiently), 110 volts from your generator or shore power, or propane.
> Many
> people run down the road with the fridge on propane (I do not) but "Mac
> the Fire Guy" says to never have your propane valve on while underway.
> If you are running your generator while driving, and your fridge is set to
> the "Auto" position, it will be running on 110 volt AC power.
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final drive,
> Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear American
> Eagles,
> Solar battery charging. GMCSJ and GMCMI member
