Ken, I can only think of one GOOD and PRACTICAL reason to change to the
Mercedes fan. The stock clutch fan "ain't what she used to be". I have
replaced 4 of them on my coach, and too many to remember on customer
coaches. If you have a good one, hang on to it for dear life. What is out
there in the parts stream is a long, far, cry from what was originally
fitted to our coaches. Since Delphi filed for bankruptcy back before Olds,
and Pontiac, and Saturn went belly up, the aftermarket parts stream is
F.U.B.A.R. Water pumps, fuel pumps, fan clutches, alternators, starters,
etc. are crapola. If you have local rebuilders for that stuff, support
them. They are a dying breed. I would suggest taking a hard look at the
Mercedes fan drive at someone else's expense. If it proves reliable and
trouble free after 30 to 50 thousand miles of GMC coach use, it might be
worth going to it.
78 GMC ROYALE 403
> > I watch all of these things and options for the radiator fans.
> > The question is why?
> > The cooling system should cool the engine on it's own most of the time
> and only require additional boosting, meaning more air flow, is rare
> > conditions. If you can not keep the engine at normal operating
> temperature then fix your cooling system problem. Do not try to cover it
> up with
> > more fan forced air cooling.
> > I realize that there are a few circumstances where additional fan forced
> air is necessary, like extensive slow speeds like idling, or stop and go
> > driving, or towing in a large load up hill in warm/ hot weather. In
> those occasional circumstances the stock fan and clutch has worked for many,
> > many years on thousands on maybe millions of vehicles.
> > Fix the cooling system before monkeying around with a fan or clutch.
> Ken,
> The answer to your question is simple....
> I am on the third fan clutch.
> One got so loose I was worried that it might actually let go of the blade.
> The replacement locked up on the way to the Western States Rally. When I
> say locked up, if the belts didn't slip, I could have turn the engine over
> compression. I bought what I could find and replaced it in a parking lot
> at Amana.
> That one came on too soon and stayed on so long that the thermostat never
> opened. That put the fuel rate down to 8.6 and it was loud all the time.
> With some help, I got all the parts together and put in the electrically
> controlled fan.
> This one comes on at 210°F and goes off at 195°F. I can never be sure if
> it is running when Mary is driving.
> It was a real good mod for me.
> Matt
> Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> Electronically Controlled Quiet Engine Cooling Fan
> OE Rear Drum Brakes with Applied Control Arms
> SE Michigan - Twixt A2 and Detroit
