John,
If you're still using the OEM style air bags, you should consider going to
the Sully Bag system. If using one of the 4-bagger systems,
contact the bag manufacturer for a possibly higher capacity bag. Fatter
bags will let you carry the weight at a lower pressure, saving
you from problems caused by the higher pressure. At least, that's my honest
opinion.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Saturday, April 29, 2017 10:20 AM
To:
Subject: Re: [GMCnet] Any idea why my late 78 compressor discharge line is
so tiny? .125 OD, .075 ID. REALLY.
> The lines are that size because that is what GM was using in the cars
> those units were designed for. No idea why they designed THOSE that way!
> Those two compressors also incorporate the exhaust valves. If they are
> replaced, an exhaust valve for each side will need to be added. This
> change,
> or some other system, such as the wireless system, may be desirable, as
> those compressor/exhaust valve units are getting VERY expensive.
> I have added those exhaust valves and installed Viair compressors on the
> 78 stretch. It goes up & down quickly! I considered a wireless system,
> but
> it's so heavy it needs more than 100psi to achieve full raise.
> John Shutzbaugh, Vacaville, CA;
> 77 Eleganza, bought it new, can't blame PO, and
> 78 Buskirk stretch, "What were we thinking?"
