Any idea how to fix this?
you may want to tell us what youre doing. there is zero context
From: Gmclist on behalf of Shawn Bennear via Gmclist
Sent: Sunday, September 15, 2019 9:35 PM
Cc: Shawn Bennear
Subject: [GMCnet] Any idea how to fix this?
I was looking as to how to fix this... It does push back in place, just not sure how to repair. Any thoughts? Appreciate any suggestions you may
have...Thanks
http://www.gmcmotorhomeworld.com
1977 Palm Beach, 403 V8 w headers.
Ken is correct there are recommended glue for that repair. I don't remember what it is I needed to repair that same panel in my coach more then 20
years ago and it held all these years. I probable used some kind of contact cement or silicone adhesive. Jim k or Jim bounds most likely will be able
to help with the correct adhesive.
Roy Keen
Minden,NV
76 X Glenbrook
SikaFlex 221 will bond that back together....Plexus is another bonding agent that will work as well but it's a 2 piece mix and requires a special gun.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Am I missing something? I never read what Shawn was trying to fix, just
that he was trying to fix something....
Rich
On Mon, Sep 16, 2019 at 5:28 AM tonka6cuda6--- via Gmclist <
> gun.
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
Separate the loose outer panel from there to the lower edge and rough up
backside of the panel and where it was bonded then apply panel bonding
adhesive in the joint and clamp in place until cured.
Sully
Bellevue wa.
On Mon, Sep 16, 2019 at 10:54 AM Larry Davick via Gmclist <
> http://www.gmcmotorhomeworld.com/bodyissue.jpg
> Larry Davick
> A Mystery Machine
> 1976(ish) Palm Beach
> Fremont, Ca
> Howell EFI + EBL + Electronic Dizzy
