Any experience with Lock and Lube Grease coupler?
Matt Colie
11,101
807
113
South East Michigan near DTW
I try real hard to over grease my coach, but even with a really good grease gun, it is still a bear.
It is always tough to get the coupler on the Zerk and then keep it on while pumping.
I am hoping someone has spent the money for one of these and can offer a first hand opinion:
https://locknlube.com/collections/locknlube-grease-coupler
Thanks
I picked up a different style one without the 'rocker' type release at SEMA a couple of years ago. The one I bough has a disconnect similiar to a
quick disconnect air fitting. The only problem with it is that disconnecting it when under pressure can be a real chore. The manufacturer offered a
open/close valve that would cure the problem but I haven't yet adapted it to the gun. The one you show may cause some issues with the size in tight
spots. If you can fit it in, it sure makes things easier.
Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
Matt, It looks like a great solution. I've always hated grease fittings, the design hasn't changed in generations. From my dad's old 30's era
tractors through to my new kubota and all the vehicles I dealt with in between, most leaked.
Oh what was I thinking, manufactures always are changing something that works well and redesigning to find something that sucks. The grease nipple
design sucked from the beginning so they will stay with it. Just my 60 years of experience.. /Rant Off
Bruce Hislop
ON Canada
Hubler 1 ton front end
Matt,I bought one this summer and it works greats.
JR WrightMichigan (On location in Tucson)
To:
Cc:
Sent: 08-Dec-2017 17:40:37 +0000
Subject: [GMCnet] Any experience with Lock and Lube Grease coupler?
while pumping.
https://locknlube.com/collections/locknlube-grease-coupler [1]
Thanks
Links:
[1] https://locknlube.com/collections/locknlube-grease-coupler
I'm listening for responses--more than once I've stripped or broken a zerk
with a coupler that snaps in place too aggressively. My tractor has zerks
screwed into plastic that I've given up on being able to lube--I just
replace the plastic wheels more often.
Rick "in the hopes that these require no insertion or removal grip when the
handle is pressed" Denney
> -----------------------------------------From: "Matt Colie"
> To:
> Cc:
> while pumping.
> Thanks
> Matt
> Links:
Rick Denney
73 x-Glacier 230 "Jaws"
Appears too bulky to get in a lot of tight places. With a one hand opperation gun you can hold the hose with the other hand. (Assuming you have two)
Pete -
I have a similar DeWalt cordless grease gun that is 18 volt and it does a
great job. Are there any customer ratings on the Amazon site? I forgot to
look. I use the DeWalt tool on the GMC front suspension and rear bogies and
on other equipment such as cars and lawn tractors. No problems at all,
cannot comment on the specific Amazon item but they probably have a
satisfaction policy that protects you from something inadequate.
The grease cartridges that I have used (Valvoline Synpower w/moly and Mobil
1) tend to separate in the gun and make a mess, no reason to think that this
one would not have the same "problem". I pack the inside of the case with
paper towels to absorb the mess and that helps. I have added several
specialized nozzles to the kit to increase its usefulness.
Bob Burkitt Cincinnati Sent privately
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Pete
Smith
Sent: Saturday, December 9, 2017 9:52 PM
Subject: Re: [GMCnet] Any experience with Lock and Lube Grease coupler?
Anyone got a cordless grease gun like
this?https://www.amazon.com/gp/product/B000H5FXL4/ref=ox_sc_act_title_1?smid
=ATVPDKIKX0DER&psc=1
Should make the job a little easier.....
Pete
Cary, NC
1978 Center Kitchen Royale.
I have a $15 Harbor Freight air-powered grease gun which has worked well. Might be a potential inexpensive alternative for some folks.
Hi Matt, It's good to hear that me as a newby are having the same issues. I have been wondering what I did wrong. No help to you, but thanks for
posting :)
> Thanks
> Matt
1973 26' Canyon Land (Mello Yello) (TZE063v101302)
Los Angeles, CA ('98 NL 2 USA)
As a new owner myself, this post leads me to think I am remiss for not having done any greasing to date (one year and about 3000 miles since
purchase). Knowing that we frequently use remotely mounted zircs for hard to reach bearings on pumps, air handlers, etc. at my facility, perhaps this
product could be adapted for hard to reach zircs on the GMC: http://greaseextensionhoses.com/
Wackster - 1976 23' Crestmont
Baltimore, Maryland
Would air pumps on a 78 Royale be up to powering a air grease gun?
Cary, NC
Not much way to tap into them, but the pressure is there, don't know about
the volume (cfm). They don't make much of that.
78 GMC ROYALE 403
Cary, NC
I like that idea. If it's easy it will get done much more often.....
Just have check every now and then it's still connected :)
Pete
> this product could be adapted for hard to reach zircs on the GMC: http://greaseextensionhoses.com/
Cary, NC
The factory supplied air compressor do not have anywhere near the
volume needed to operate any air tool. I had a York air compressor
system by Darcy Moses that I got in 1999. Darcy has since passed on
and no one has picked up the design. My 75 Avion also has the york air
compressor layout on it. This compressor can operate small air tools.
JR Wright
Michigan
To:
Cc:
Sent: 11-Dec-2017 22:57:03 +0000
coupler?
Cary, NC
Cary,
In a word, no. If you put a larger tank in there and were will to wait while it recovered, maybe.
Pumping the grease gun isn't the hard thing. What is hard is getting to zerks and then seeing the grease come out of the seals.
The grease gun I looked at wanted 100 PSI max and 4 CFM.
You could shoot one and wait for the compressor to stop then shoot again.
If you are retired you may have enough time.
I put a tee in the line with a 50-foot coil hose to pump up a low tire. It
takes a lot of waiting to bring a time up the last 20 lbs.
> JR Wright
> Michigan
> -----------------------------------------From: "Pete Smith"
> To:
> Cc:
> coupler?
> Cary, NC
*John Phillips*
Quote:
> (one year and about 3000 miles since purchase). Knowing that we frequently use remotely mounted zircs for hard to reach bearings on pumps, air
> handlers, etc. at my facility, perhaps this product could be adapted for hard to reach zircs on the GMC: http://greaseextensionhoses.com/
> Pete
James and Pete,
Greasing all 18 normal places on a GMC is only difficult because some are difficult to get the coupler to stay on. If you have a two handed grease
gun it can be very difficult to keep it on. If you get a one handed grease gun, that helps a lot. It does not require a lot of grip strength to do.
I suggest that you consider getting either the lock on coupler (I ordered one) and a good grease gun, or a good one handed version. Some years back I
settled on a Lincoln 1133. This was after I had tried a similar tool from Hazard Fright. I took that one back. I am hoping that the lock on coupler
and the Lincoln 1133 will finally make the job trivial. (But I am sure it will still be nasty.)
As a ship's engineer, I am very familiar with remote grease systems, but the problem the coach represents is that most of the places you really need
to grease are on moving elements and remote grease lines are about as friendly as brake hoses. I don't think I want three more brake lines to each
knuckle.
The real reason you have to keep at greasing things is because the seals are bad. Out in my garage is a 1995 Honda that has over 250K on it. No part
of the running gear has ever been relubricated. If I could get parts with those kind of seals for the coach, I would do so in a heartbeat.
There is the problem with any non-manual system, you can't feel the grease go in. This is a big issue where you cannot see the boot swell. If you
use a pneumatic gun, they happily chuff away even if there is no grease going in. I was able to recognize an issue with a lower ball joint because it
would not take grease. That allowed me to replace it before a critical failure.
Added note: There are now a number of cordless powered grease guns available. A quick E-bay survey found some good names available in the 200+$
range. Even I am tempted. When you consider that you will be charged at least an hour for a front end lube for the coach and at any shop I would
trust, that will almost cover the cost of that tool on the first use. (Yes, I do run my life at the bottom right corner of a spread sheet.) And you
can be sure it was done right. You can always get some native guide from the Black's list to supervise.
If you have an older coach, (the exact years escape me at the moment), the lubrication for the bogie pins was set up wrong. So, I carry a straight
gun onboard and they to hit them every 1K. Those are just 4 of the 18. Those other 14 you get on your back on the ground or on a lift. Except the
two on the steering shaft, I take the grill out for those.
Many of us have also gone to a synthetic grease as they have less heat issues and almost don't age out. I prefer one that has MoS2 in it because I
love that stuff. (Unless you get it on something you like.)
In the owners manual, GM called for a 3K service interval for the greased parts. That should be good enough. But way early in my mechanical career
(that spans over 50 years) I learned that grease is always cheaper than parts....
Is there any advantage with pneumatic vs battery guns?
I would think the battery guns might be easier to get around being you don't have a hose to drag around. But I don't have experience with either, just
the old style ones.
Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi.
Houston, Texas
