Not sure I'd want a transverse engine on anything doing heavy duty pulling...
Just throwing this out there, but the only other heavy duty, longitudinal drivetrain, front drive application I know of is some E-450 transit vans
were converted to FWD. They use them here at the State Fair of Texas as parking lot shuttles. The FWD lets them lower the van floor for ease of
entry. Some quick internet searching reveals they were common on transit busses in Canada as well. The Canadian ones are running old Navistar 7.3s
and have some sort of a Carraro H.S. drivetrain running forward to what looks like a heavy duty Dana front axle. Not sure if the State fair busses
also run the Carraro, but I can confirm by the sound they are definitely running 7.3s...
So as someone else here mentioned... Use a GM 1 Ton front end instead of the dana used on these fords powered by a driveshaft off of this Carraro
unit... Either use an adapter or maybe Carrero has a GM Bellhousing pattern available.
Hal had also mentioned using a NP205 converted for FWD operation as another drivetrain option to get power from a longitudinal mount engine to the
front wheels... Nice thing about that setup is NP205s are everywhere...
http://www.thedieselstop.com/forums/f14/odd-e450-bus-set-up-310304/
Here's one that was up for auction just a few days ago. Went for 1800 Canadian... If the 7.3 runs well, you should easily be able to get 1800 just
for the engine. You'd end up with a nearly free drivetrain...
https://www.govdeals.com/index.cfm?fa=Main.Item&itemid=3&acctid=5511
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
Howell Injection,
Fort Worth, TX
