An electric puzzler
randy1
1,979
To all who love electricity-
There is a wire that attaches to the Positive Power post on the firewall and this wire comes from a relay above and to the right of the boost solenoid. This wire, for some reason, carry's DC voltage off the aux generator in back and the coach will not start unless this wire is attached there.
So, waddy think is allowing aux gen power to come into the main battery electrical circuit and why must it be connected for the engine starter to turn?
Also, does having this power going to the battery put my alternator diodes at risk?
These should explain a little better:
http://www.gmcmhphotos.com/photos/showphoto.php?photo=24551&ppuser=1678
Randy
1973 26' Painted Desert
Ahwatukee (Phoenix) AZ
To unsubscribe or change your settings - http://www.gmcnet.org/settings.htm
Donate to support GMCnet - http://www.gmcnet.org/support.html
All I have is questions at this point. What you describe makes no
sense to me. Maybe someone will understand perfectly, but I sure
don't.
Does the engine turn over and not start or not turn over? How many
batteries are connected to that post? Is there an isolator between it
and the house and starter batteries? Is it possible that the starter
solenoid is being powered from your aux gen battery?
> Randy
Ken Coit, ND7N
Raleigh, NC
1978 Royale Rear Bath, 403, 3.07
Here's what I know:
There are two batteries up front and one to start the genset in the back. When the generator runs, it sends 16-19V (depending on genset load) to the main starting battery only. There is an isolator (new) installed. If the wire in the photo is removed from the positive power post, the battery doesn't get the genset voltage, but then again the starter gets no power either. If it's attached, the engine starts and runs fine.
I'm mostly concerned about running the genset (to power roof air and fridge)while the engine is running for fear that the reverse flow of power from the genset to the battery will affect the alternator.
Randy
This seems to make no sense. I can only suspect that wires are "traded"
between the point they are intended to go, and where they are.
May I type a bit, and see if anything is enlightening? The red and
red/black(?) wires that disappear "up" should go to the ends of the
isolator. One is correctly connected to the chassis +12 V post. The other
should be going to the house battery. The isolator center post (black wire
coming down with red wire) on mine goes into the harness, and then to the
main engine alternator output.
I think your "this is the wire" *should* be taking 12V chassis power to
accessories, not supplying chassis power. The 12V chassis post should have a
wire going directly to the chassis battery (the big red one I see going
toward your new boost relay?) The boost relay post that wire connects to
should have the huge wire to the chassis battery. One explanation might be,
the red wire going to the big relay post is actually one of your wires to a
battery, and the wire that should go there is connected to your isolator.
You could disconnect that wire; if the ring terminal on it still has 12V, I
think it's in the wrong place.
Wanna check that and report (or tell me to be quiet)?
Walt Taylor
Elroy, TX
'75 Eleganza, '75 Transmode
> Here's what I know:
I am totally confused so I have no constructive ideas. I do have some comments that might confuse the situation even more.
1. I thought that the 73 GMCs had a small starting battery in the rear separate from the house battery(s). Do you have this 3rd battery? If not then it sound like this coach has been modified to make it start off of the house battery(s). If this modification has ben done I suspect it was done incorrectly.
2. My only other comment is if you are reading 19 volts anywhere in the house or engine 12 volt electrical systems, THIS IS TOO HIGH. You need to find the source of the 19 volts and fix it before you damage something. If you so not have an APC from Gene Fisher installed on your alternator you need to do this before trouble shooting anything else.
I think Randy's gone to bed; can we talk among ourselves? I *think* he said
Kohler with no integral charging, so that implies 115 AC batt charger doing
the 16-19V; no 3rd battery; maybe charger's confused by high series
resistance connection to batt?
Randy's been "crying in the wilderness", and getting no response, I think
'cause we read, mutter "WTF,O" to ourselves, and say either that or nothing,
neither of which is any help.
His pix at:
show the wire he disconnects that makes the (I think) main engine starter
solenoid not work. This tells me, something's hooked up really wrong. Those
pix show other "innovative addenda", too.
I hoped to give him some concrete suggestion to start looking.
Walt
> incorrectly.
The wire Randy identifies as providing power to the starter solenoid
probably provides 12 V to the ignition key switch??? Is he telling us
the Onan has to be running so the coach engine will start? I wonder
what kind of a meter he is using to see 19V. I can see a battery
charger going to 16V with high series resistance buy don't see 19V on
an open circuit. Maybe see what the meter reads on his car battery?
This reminds me of some $150,000 boats that had all red wires going to
one 3/16" bolt and all black wires going to another 3/16 bolt. No buss
bar or fuse panels. Then the salt environment began the fun.
Gordon
> His pix at:
> Walt
>> incorrectly.
Okay, I'm awake.
Yes there is a 3rd battery in the back to start the Kohler.
No, it doesn't need to be running to start the engine.
The 16-19VDC (125V AC in the coach) is high coming off the Kohler, but the guy who set it up said that it might be a voltage regulator and that parts might be hard to come by, so I've lived with it for now.
The wire I pointed out is carrying the DC voltage, but why is it necessary to be connected in order to power the starter?
For that matter, why is there a positive power post at all and just what should be hooked to it?
Thanks for burning the midnight oil for me.
Randy
Here's some more pictures
http://www.gmcmhphotos.com/photos/showphoto.php?photo=24553&ppuser=1678
The cruddy relay above and to the right of the solenoid is where the wire in question comes from.
http://www.gmcmhphotos.com/photos/showphoto.php?photo=24554&ppuser=1678
Sorry about the second one, the lid was clobbering me on the head just as I snapped the picture.
Randy
The wire pointed at in the picture is, or should be, the fusible link. It is about 14 gage wire designed to burn open if there is a non-fused short in the coach. It should be connected all times. A bad or disconnected fusible link will cause the coach engine driven alternator to go over voltage since the voltage sense line for the alternator is past this point.
Do not ever leave this wire / fusible link disconnected when running the coach engine. In theory, if the coach is wired correctly, the coach engine would not even start with the fusible link removed.
You have got a wiring problem somewhere but this wire is not it.
The generator should start independently from the engine batteries. I'm not sure where your problem is and it is very difficult to guess remotely on where you should start looking. If I was there with a volt meter and a wiring diagram I could probably find the problem. Sorry...We will keep trying to help you remotely.
You need to think of the GMC as two separate 12 volt electrical systems. They never should be hooked together. There are two exceptions to the rule:
1. The coach engine driven alternator charges both systems (house and engine) through the isolator
2. The battery boost solenoid hooks both systems together ONLY when the switch is pushed on the dash for emergency starting if the engine battery is low.
Do you have a boost switch that is not spring loaded and could it be in the wrong position?
Randy,
I hate this format, but I am going to comment in-line for clarity because you have a lot going on here (some that should not be..)
=Yes there is a 3rd battery in the back to start the Kohler.
It won't last long if you don't fix this.
=No, it doesn't need to be running to start the engine.
Not a surprise...
=The 16-19VDC (125V AC in the coach) is high coming off the Kohler, but the guy who set it =up said that it might be a voltage regulator and that parts might be hard to come by, so I've lived =with it for now.
The regulator is not hard to come by. It is not cheap, but it is a Prestolite part used on all the Onan and Kohler engines for years. It comes in a 10 & 15 amp version it doesn't mater which you get because it does not need to be plug compatible (identical connection layout). Just get the AC and DC connections correct. A small engine shop can match it for you. For the apology being, unplug it. The regulator is a finned jobbie one the left side as you look down on the pulled out unit. If you remove both connections and tape them individually to keep things safe until the regulator is replaced. Apologies
=The house and main batteries both read 12.6 VDC when separated from the Kohler.
Good. But Check the Water Level.
=The wire I pointed out is carrying the DC voltage, but why is it necessary to be connected in =order to power the starter? (Maybe it is only powering the ign sw)
This is probably a result of a miswiring by some service person of PO. Start by checking the fuse on the unit's control board. The remote start circuit has been separated from the crank circuit. The start battery is probably alive only because it had the house battery to keep it from being fried. The rear battery may be bad already and the house battery is helping you limp by.
=For that matter, why is there a positive power post at all and just what should be hooked to it?
This post is a great convenience for person building the wiring. On the boats that I rewire, I have a rule about one and one only connection to a battery terminal. It is a serious problem when you go to reinstall a battery and there are about a half a dozen loose little wires that have to get put on one post or the other.
=Thanks for burning the midnight oil for me.
Any Time.
Good Luck
Matt Colie
Matt & Mary Colie
'73 Glacier 23 Chaumiere (say show-me-air)
SE Michigan
Randy writes...
> Okay, I'm awake.=20
> Yes there is a 3rd battery in the back to start the Kohler.=20
> No, it doesn't need to be running to start the engine.=20
> For that matter, why is there a positive power post at all and just what =
> Thanks for burning the midnight oil for me.=20
Randy, the only thing I think will help is to try to explain, briefly,
how the system is supposed to be wired, and then you try to identify
the wiring that does those things. Much of electrical troubleshooting
isn't looking at wires, it's looking at where they are connected, and
where the wires going to those connections are connected. It's also
injecting a voltage in one spot and seeing where else it pops up.
from your pictures, you have an isolator and three batteries common
for an early coach.
Here's how GMC wired it:
The battery in the back goes to the generator. The Kohler generator
produces 120VAC, which is used to power a converter, which produces
13.6 volts for the house circuits. This converter is inside the coach
somewhere. That converter is used to charge the generator starting
battery, so there should be a wire going from that converter back to
the battery that starts the Kohler. If you had an Onan, that battery
would be charged by a small "converter" mounted on the Onan and
separate from the house converter.
The house converter feeds a bank of fuses, which feed the circuits
used by the 12-volt lights and appliances in the house. There is also
a wire going from the converter to the house battery, which is on of
the batteries up front. That wire charges the house battery.
The engine alternator has two wires of interest. GMC wire the fat one
to the center stud on the isolator. The thin one goes to the 12-VDC
main terminal that you pictured. The thin one is the sense wire that
tells the alternator how much voltage it is producing, and the fat one
is the supply to charge the batteries and power the chassis 12-volt
devices, including the ignition, the air suspension, and just about
everything controlled from the dashboard except the radio.
The engine starter is a special beast, because it requires too much
current, and because it must be powered before the alternator is doing
anything. Thus, there should be a fat wire going from the engine
battery directly to the starter. There is no "starter solenoid" that
is separate like on a Ford--the solenoid is mounted right on the
starter and the fat wire goes right to it. There is a thin wire that
goes to the starter solenoid also. This wire is energized only when
you turn the key to the "start" position. There may also be another
thin wire going to the distributor on old coaches to provide voltage
to the ignition during start.
That brings us to the boost solenoid, of which there should be only
one on your coach. There is a wire going from the isolator to the
engine side of the boost solenoid. That wire is attached to the bottom
terminal of your isolator in your picture. It connects to the left
stud on the solenoid just below the bottom of that same picture.
The house battery is charged by the red wire, which goes from the
upper isolator stud in your picture to the right-side stud on the
boost solenoid. (I'm assuming that battery in the rear is the house
battery, as is usually the case.) The fat wire from the right side of
the solenoid goes to the house battery, and the fat wire from the left
side goes to the engine battery. (Left and right might be reversed on
someone else's coach, but that's why I see in your pictures.)
Going back to the main Vehicle Battery Positive terminal, there are
several wires attached to it. One of them controls the boost solenoid
(the red one). The one you point to looks to me like what should be
the field sense wire for the alternator. You say that it goes to the
relay, but does it really connect there? I see the wire but not the
connector. That relay and the one above it power the air-conditioner
blower motor, as I recall. Now, the AC blower motor is powered through
voltage-reducing circuits to reduce blower speed. But at high speed,
the blower is fed by one of those relays directly from the battery so
that it doesn't overload any intervening circuits. The blower does not
blow when the engine is being started, so the circuits controlling
those relays come from the part of the fuse block that is turned off
during starting.
If the starter solenoid is getting its power through that circuit, I
would wonder if there is a fault in the ignition switch or somewhere
else.
What should happen during starting is the ignition switch connects the
wire going to the starter solenoid to power, which then closes a big
switch to feed high starting current through the fat wires from the
battery. Those fat wires are not the story--if you were really
powering the starter through that thin wire, it would burn up.
Were I you, I would disconnect all the batteries, remove that wire
from the main Positive terminal, and then apply voltage to it using a
jumper from one of the batteries. If that wire is the only one to get
power, then it should be the only source of power in the coach. Then
follow that wire and the wires connected to anything its connected to,
and measure voltage to see what is switching what. If that ran into a
blind alley, I would start from the other end, which is the output of
the house converter. Unplug that converter from its receptacle and
plug it into an extension cord to power it separately, and then trace
forward to see where power goes. You should not have power in any of
the chassis circuits powered by the converter. Maybe tracing from both
ends will meet in the middle somewhere, maybe not. But keep track of
where you see voltage and that will help you ask questions that will
gives us better clues.
Good luck.
Rick "who suggests labeling wires as you identify them" Denney
'73 230 Ex-Glacier "Jaws"
Northern Virginia
> Randy writes...
> Randy writes...
> **SNIP **
> The battery in the back goes to the generator. The Kohler generator produces 120VAC, which is used to power a converter, which produces 13.6 volts for the house circuits. This converter is inside the coach somewhere. That converter is used to charge the generator starting battery, so there should be a wire going from that converter back to the battery that starts the Kohler. If you had an Onan, that battery would be charged by a small "converter" mounted on the Onan and separate from the house converter.
> Rick.
> From other postings here I believe the Kroehler uses an internal flywheel driven battery charger and a voltage regulator to charge it's starting battery, just like the Onans. I have never seen a Krohler generator myself so I cannot to speak authoritatively on this.
> The house converter feeds a bank of fuses, which feed the circuits used by the 12-volt lights and appliances in the house. There is also a wire going from the converter to the house battery, which is on of the batteries up front. That wire charges the house battery.
> The engine alternator has two wires of interest. GMC wire the fat one to the center stud on the isolator. The thin one goes to the 12-VDC main terminal that you pictured. The thin one is the sense wire that tells the alternator how much voltage it is producing,
> Also alternator sense line is connected on the down stream side of the fusible link at the horn relay. The 1975 wiring diagram shows it as a 12 gage red wire.
> **SNIP **
> Going back to the main Vehicle Battery Positive terminal, there are several wires attached to it. One of them controls the boost solenoid (the red one). The one you point to looks to me like what should be the field sense wire for the alternator. You say that it goes to the relay, but does it really connect there?
> **SNIP **
> Yes, the sense wire should connect there as this is the horn relay that he is talking about and not the blower motor relays. The wire he is pointing at is the fusible link.
> ** SNIP **
> Northern Virginia
> Rick
> After 20 minutes of screwing with it I gave up trying to quote on this answer. What a PIA. Anyway above are my comments.
> Ken B.
Randy: I always like electrical sleuthing and I am over in the Queen Creek area for the winter (and another couple of weeks). If I can be of any help to you let me know. I would be glad to come over and work with you on this. 208 816 3901
I have had some luck on my own rig, figuring out what the PO's did and getting it restored to the original condition. Mine is a 76, and has somewhat different wiring, but I am sure we could figure it all out.
Rob Allen
'76 x-PB
Ken Burton writes...
>> this.
Good to know. I was going on the implications of other posts.
Also good to know. Mine wasn't wired that way. That's the horn relay?
Hmmmmm. Gotta look at that again. I saw your post after writing mine.
Where does the fusible link connect to on the other end? Is it between
the horn relay and the terminal? I thought the fusible link needed to
be between the fuse block and the terminal, but maybe the fuse block
borrows the same connection on the horn relay. Gotta look at that
again.
It's easy with email, heh, heh.
Rick "poking a sharp stick into a sore spot" Denney
Northern Virginia
Well, now the 3rd battery is isolated to the gen only. It doesn't get re-charged. More on that in a minute.
The unit has two c/b's that trip if overloaded. I'm not aware of any other fuses, but they may be inside the control box
There was another red wire that was wired between the Kohler starter solenoid and the large C/B behind the boost solenoid. To my surprise, with the 3rd battery disconnected, the Kohler started! It was drawing power through that little wire, through the solenoid to the starter. I think that wire's original purpose was to act as a recharger line, but the wire should have gon eall the way to the 3rd battery, not just to the solenoid, to do that.
[/quote]
Randy
[/quote]
I think I'll take you up on the offer. Thanks. Alot!
Randy
for an early coach.
No charger wire on my Kohler battery. The converter is a small green box clearly labeled Power Converter.
So there should be around 13.6 volts coming into the forward battery bank when the Kohler is running. OK, that helps. I thought the alternator charged the house and main batteries.
So the 12V accessories are not buffered through the battery, but are powered directly from the alternator?
Actually the main battery is behind the house battery(no doubt for convenience :o ). I can't make the boost solenoid do anything and it too is new. As far as I can tell, the left side of the solenoid is house-related and the right is engine electrical-related.
during starting.
As far as I can tell. I'll try to remove the relay and see more clearly where it attaches. If I could simultaneously monitor voltage while cranking the engine, I might get a better feel for what's going on.
If that ran into a
Great idea!
Well, I've done that on about a dozen wires under the dash. I probably only have 2-3 hundred more to go!
Randy
I just looked at your pictures again and the black wire in question is definitely the fusible link. With the wire in question disconnected almost everything on the engine battery side of the coach should be dead. This includes the ignition switch, power through he ignition switch to the coach engine starter solenoid, and all lighting.
Do you have a GMC wiring diagram? If not, Billy Massey has one on his web site. It is too big to be viewed with Internet Explorer. You can view it with Firefox or I can pull it down, compress it and send it to you.
Randy writes...
The alternator DOES charge the engine and house batteries when the
engine is running, but does so through the isolator. The wire that
connects the house battery to the house fuse block (which should be
right next to the converter back in the coach somewhere) also carries
charging voltage when the converter is energized. The converter will
be energized either when running the Kohler or when connected to shore
power.
The alternator goes to the isolator only. The voltage from the
alternator is high, because the sense wire that controls the
alternator voltage is downstream of that isolator. The isolator will
drop the voltage about 0.7 volts. The engine side of the isolator is
connected to the engine side of the boost solenoid, which is connected
to the engine battery. And there is a mid-size wire from the engine
side of the boost solenoid to the Vehicle Positive terminal.
Everything in the chassis electrical system is fed from there. As long
as the battery is connected to that system, it will act as a tank and
provide excess current when necessary.
Yes--I missed that the red wire from the upper isolator terminal goes
to the main positive terminal on its way to the right side of the
boost solenoid.
If what Ken says is correct (and I'm sure it is), then that wire you
are pointing to should go to ultimately to the master power connection
on the fuse block. That connection is hard to see. I don't know if the
horn relay is the attachment point for that wire. If the wire goes
under the nut that is visible on the front of the horn relay, then the
red wire also visible should be going to the fuse block. Of course,
nearly all the wires in those bundles to the right that go through the
firewall are going to the fuse block, so that doesn't help much.
It's the wire coming out of the right side of the Vehicle Positive
terminal that powers the AC blower.
If the wire you point to is the fusible link, the it powers everything
on the chassis except the starter and the battery charging from the
alternator. That includes the starter solenoid and the ignition
circuit, so that should explain why the engine won't start when it's
disconnected.
Since that wire is directly connected to the battery, it will also be
energized. But it should be at 12.something volts when the engine is
not running, and 13-14 volts when the engine is running. The Kohler
should have no effect on that. There should be no connection between
the output of the converter (which is powered by the Kohler) and the
fusible link. The output of the converter should be isolated from it
by the isolator.
Since the boost solenoid is new, you might check with a voltmeter to
make sure that it isn't wire such that it is always on. In fact,
remove the small wire from the boost solenoid and listen for a click.
If it clicks when you touch that wire to the small stud on the side,
and the boost switch is off, then disconnect the other wires on the
boost solenoid and check for continuity across the big terminals.
There should be none unless that small side terminal is energized.
And just for kicks, make the boost switch is off (down). The early
coaches didn't use a momentary switch, and you can leave them on by
accident. If that's the case, the boost solenoid will be energized and
then converter voltage will be connected to the engine battery.
A standard converter should put out 13.8 volts. But the standards ones
were large and noisy. If yours is small and green, then it might be a
multistage battery charger. A multistage charge might have a separate
sense line, which complicates the situation considerably. But even
without that, it will put out 14ish volts during initial rapid charge.
Use a digital voltmeter. Most analog voltmeters lack the precision to
monitor multistage battery charging.
I once saw zillions of labels under Ken Henderson's front hatch, and
asked him if he had enough labels. His response, "Well, since not all
the wires are labeled, the answer has to be no."
Rick "whose wires are labeled in his head" Denney
Northern Virginia
