Amp draw
dean hanson
256
I suspect my suburban heater fan is drawing heavy amperage when operating.
How can I make that determination?
Dean C. Hanson 75 Avion (with a meter but realy doesn't know how to use it)
P.O.Box 2096
Fremont, Ca. 94536
(510) 657-9600
Without a pile type meter-- you could check spec and put in a fuse just smaller until it blows . You can narrow it down pretty close. Often a drop
of oil on each motor bearing will dramatically lighten the draw
You can find the fuse that feeds the fan, remove the fuse and put a DC
current meter in its place, read the current then switch on the fan and
note the difference. Use a meter that can take the full load the fuse is
rated for.
On Tue, Jan 22, 2019 at 1:43 PM Dean Hanson
> P.O.Box 2096
> Fremont, Ca. 94536
> (510) 657-9600
*John Phillips*
Dean:
The easiest way to check the amp draw is by using a clamp on ampmeter that works on DC. I have two, give me a call and I'll loan you one. If you want to purchase one, Klein Tools has a model for about $120.00 and will read up to about 400A.
> P.O.Box 2096
> Fremont, Ca. 94536
> (510) 657-9600
