If you do choose to go with an upper corrugated hose, it has to sort of "S" around from the engine to the upper rad outlet. I was concerned the hose would either droop into the pullies, or lift and rub on the coach floor with pressure and heat changes over time. I ended up taking a large adel clamp, and mounted it to the top bolt on the alternator. I then ran the hose through the clamp with the hose surrounded by a cut and split piece of my old hose, which seems to do a good job isolating and securing it.
This is the March Racing System that I had Cliff Golby alter by not using the engine driven dash air conditioning compressor and replacing with a second Balmar alternator.
This was my design for the alteration.
So the design meant that there is a new water pump, power steering pump and 2 new Balmar alternators.
In my design, the 12vdc Balmar alternator did not fit exactly in the two mounting holes, so a custom 3 hole bracket was required for the lower right mounting bolt. I still would have to u=install a custom length belt but it would be much closer in length to the "stock" one.
However, when Cliff installed it he said that he had to design and build a custom bracket for the new alternator because the cooling waster hose was in the way.
Also, he switched the positions of the two alternators, with the red alternator on the top instead of on the bottom.
I also have a box of parts from the March system that were not installed, including the original belts that were not used.
I also have a brand new, never used engine driven air conditioning compressor. It is a bright shiny aluminum Sanden 7176 compressor.
The bolt to bolt dimensions for the Sanden (5.787") was slightly larger than the Balmar 604-120-K6 alternator (5.470"). The difference in distance is that the Balmar would rotate slightly clockwise by tightening the tensioning turnbuckle by 0.32" or about 5/16".
This would slightly shorten the belt, while the other alternate would lengthen the belt.
Can you spot the differences?
I have often been unhappy with this arrangement. It also means that the longest flat belt has to be longer than the belt that was sized for the Marsh system. Therefore, it is a very odd duck.
I thought that if a 90° hose elbow at the water pump, perhaps the alternator could be moved back into the originally designed position.
The engine is running fine as Cliff installed it.
Should I do anything or should I just let the current installation be?
