There is a stock Olds aluminum intake that will work for us. The casting nu=
mber listed in a post before was wrong. The casting number for the large po=
rt 1982 to 1985 307 Olds is 22504068. Not ending in 4086. ( Thank you so m=
uch to Tom McManus for the correction, and help with my search.) One thing =
that has come to lite. This is a high demand part in the Olds committee. As=
it has larger ports then the manifold that came out the last half of the =
production year of 1985. Edelbrock make two intakes that will work with th=
e heads that our 403's have as far as port alignment. But the carb mountin=
g surface is 1/2 inch higher then our stock cast iron intake. Edelbrock #=
3711 has an EGR port at $290. # 2711 doesn't at $320. So I just went out t=
o check the clearance between my carb air cleaner, and the hatch. There is=
none. ( Body to frame pads are in place ). With the 403 being shorter then=
the 455. Why is my 403 carb air cleaner against the hatch? So were has the=
clearance gone that should be there? One thing that I could do. Is mount t=
he manifold in the Bridgeport mill. And lower the carb mounting surface. P=
ut in thicker body pads. Or find an original 307 intake manifold. I'm tryin=
g to make sure my EFI will fit after the intake is bolted down. Bob Du=
nahugh 78 Royale
nahugh 78 Royale
