Automotive alternators don't need a "load", per se. If you consider the battery
a "load", this is true.
The reason battery charging alternators destroy themselves is that the sense
wire from the alternator to the
battery sends the battery voltage back to the alternator voltage regulator. If
the battery voltage is low, e.g. 12 volts, the regulator boosts the output of
the alternator until the battery "sends back" a voltage of approx. 14.1 volts.
If there is no battery to "send back" a voltage, the output of the alternator
will continue to rise, eventually destroying itself.
> Automotive alternators need a load present or you can blow output diodes
> because voltage soars to a high value without a load present.
