Alternator remote sense
Matt Colie
11,101
807
113
South East Michigan near DTW
I have to replace my alternator. The one just removed is a confirmed kill due to mechanical damage. The replacement that I picked up years ago is
another 27SI, but I have no confidence that it is remote sensing.
Is there any kind of an external electrical check that I can do to confirm or deny that it is a remote sensing regulator??
Yes, I have gone a serious on-line search, but all Delco will tell me is that their remote sensing machines have an external terminal.
Thanks
I believe the remote sensing 27SI alternator the GMC uses can be identified by the two small male disconnect terminals on the voltage regulator. These
protrude (slightly) through the case at about the 10 o'clock position when viewed from behind. The one you want will have a small terminal marked "B"
or "Bat", alongside the one connected to the warning light. This allows the alternator to sense the voltage of the battery directly, bypassing the
diode isolator. The type you DON'T want is the so-called "one wire" or "machine sensed" alternator, which only has one small terminal for the idiot
light (if that), and one big stud and nut connecting to the battery, via the isolator in our case.
HTH
Rick Staples
> These protrude (slightly) through the case at about the 10 o'clock position when viewed from behind. The one you want will have a small terminal
> marked "B" or "Bat", alongside the one connected to the warning light. This allows the alternator to sense the voltage of the battery directly,
> bypassing the diode isolator. The type you DON'T want is the so-called "one wire" or "machine sensed" alternator, which only has one small terminal
> for the idiot light (if that), and one big stud and nut connecting to the battery, via the isolator in our case.
> HTH
> Rick Staples
Rick,
Thank you, but the problem is that all the Delco XXSI regulators have the two terminals. When this alternator was repaired once (because the
regulator failed), the installed regulator was not remote sense. I figured out in short order what a difference is makes. I am hoping to confirm
that the spare I have does have the remote sense regulator without having to crack the machine open.
Out of curiousity, does anyone have a part number for the “correct” voltage regulator?
Les Burt
Montreal
'75 Eleganza 26'
>> HTH
>> Rick Staples
> Rick,
> Matt
Isn't it like 60 seconds to zip out 4 screws and separate the case to see if jumped internally? Which brings us to the next question of is there a
correct way to disassemble without cracking the the brush holder when brushes catch on rings? I understand reassembly using a spray straw brush
keeper. Did a cs144 a week ago.
They taught us to use toothpicks to retain the slip ring brushes in GM
school. That is why there is a small hole drilled through the brush holder.
The hole also serves as a quick check to check for brush wear.
On Sun, Aug 4, 2019, 7:02 AM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Big Shame-faced confession: Some years back, after installing a combiner,
I jumpered the remote sense line to the output terminal of my 27 SI. I ran
that way for several years before installing the Cad500 (with a CS130
alternator). I never had a problem with battery condition -- but I DID pay
a lot of attention to all of my wiring, including the primary lead from the
alternator and the battery terminals.
Americus, GA
www.gmcwipersetc.com
On Sun, Aug 4, 2019 at 8:22 AM Matt Colie via Gmclist <
> regulator.
> terminal
> > HTH
> > Rick Staples
> Rick,
> confirm
> Matt
James,yes I understand the brush holder holes and the one in the rear case. They give you a metal wire keeper with nee brushes, but I like the spray
can straws. The question is for disassembly. You can't insert a toothpick or anything else while brushes are spring loaded against slip rings.
