(you can delete one of those "simply" from my statement. Your choice =) )
> Is there a way to monitor the voltage output of the ELII ride height
> sensors? To simply turn on a light if need be? I'm simply curious of the
> output in different conditions, and when the delay kicks in. Would be fun
> to study while im a passenger.
>> Remember also that pressure based control systems invert the height
>> control. In other words if you are on said crowned road, or as you use
>> fuel, passenger changes etc. the control system will do the exact wrong
>> thing.
>> For example, if you get heavier, the coach will squat, the bag pressure
>> will go up, the controller will then lower the bag pressure back to the
>> setpoint lowering the coach even more.
>> Microlevels analog ( OEM hall effect non contact ) sensors measure true
>> height. it has enough resolution to sense me leaning side to side while
>> sitting on the cab step. Having a microcontroller allows a fast adjustment
>> that gets the coach within height tolerance, +- 1/4", as fast as the air
>> supply allows, then switches to height maintenance to keep height to within
>> +- 1/8". The maintenance algorithm also keeps adjustments to a minimum, no
>> less than 30 seconds between adjusting, meaning no adjusting on cloverleafs
>> or wind gusts.
>> Campground leveling is a single button press.
>> Keith Vasilakes
>> Mound sview Minnesota
>> 1976 ex-Royale
>> ________________________________
>> From: Gmclist on behalf of Rob Mueller
>> Sent: Wednesday, July 18, 2018 9:43 PM
>> To: gmclist
>> Subject: Re: [GMCnet] Alternate,air pump
>> Jim,
>> Was I incorrect when I stated "works like the OEM system and controls
>> ride height through sensors that adjust the attitude of the coach as you go
>> down the road. If you are on a road that is highly crowned it will raise
>> the curb side automatically with no input from the driver?"
>> Regards,
>> Rob M.
>> The Pedantic Mechanic
>> Sydney, Australia
>> AUS '75 Avion - The Blue Streak TZE365V100428
>> USA '75 Avion - Double Trouble TZE365V100426
>> USA '77 Kingsley - TZE 267V100808
>> -----Original Message-----
>> From: Gmclist [mailto:gmclist-bounces] On Behalf Of
>> James Hupy
>> Sent: Wednesday, July 18, 2018 7:34 PM
>> To: gmclist
>> Rob, the OEM systems ride height is ( are) controlled in two ways.
>> 1. The original early system was entirely operated by air pressure
>> and left and right hydraulic/pneumatic height control valves that sensed
>> movement of the frame height when the load in the coach either increased
>> or
>> decreased. That moved the linkage attached to the height control valves.
>> Built into the valves was a time delay of up to 18 seconds before any air
>> was let into the air bag or out of it. In addition, there was a null space
>> of + or- 3/8" where the frame could move up or down without anything
>> happening. That is a dead space of 3/4" in the center of the travel. Small
>> road shocks of a duration of less than 18 seconds never activate this
>> system.
>> 2. The second generation of height control used the same height
>> control valves, and had the same operating parameters as the one I
>> described above. Differences in these two systems were that rocker
>> switches
>> replaced the original round knob air valves in the dash, and added
>> solenoids with valves to control the inlet and exhaust of air to the
>> height
>> control valves. Same null space and time delay as the original system.
>> 3. Finally, the Electro Level II system came out. Totally electric in
>> control of ride height. Used LED light sources aligned with photo
>> transistors to open and close electrical circuits that either opened
>> exhaust valves or started smaller compressors to raise or lower the coach.
>> Manual controls in the form of rocker switches allows the operator to
>> raise
>> or lower the coach as required. The null point is narrowed to 5° of
>> travel,
>> and the time delay is lengthened to a max of 28 seconds before anything
>> happens. Shutter wheels attached to linkage either block the led's or
>> expose them to the photo transistors.
>> Small road shocks, swales of short duration (less than 28 seconds) do
>> nothing to activate the system. All this information is from GMC manuals,
>> not from my foggy brain. What does change ride height is inputs from the
>> driver through the rocker switches, or changes in loads in the coach.
>> Jim Hupy
>> Salem, Or
>> On Wed, Jul 18, 2018, 1:59 PM Rob Mueller
>> > Keith,
>> > To me the MOST important thing about the MicroLevel system is that it
>> > works like the OEM system and controls ride height through
>> > sensors that adjust the attitude of the coach as you go down the road.
>> If
>> > you are on a road that is highly crowned it will raise the
>> > curb side automatically with no input from the driver just like the OEM
>> > system.
>> > Regards,
>> > Rob M.
>> > Sydney, Australia
>> Keith
>> > V
>> > Sent: Wednesday, July 18, 2018 8:52 AM
>> > To: gmclist
>> > Why would you EVER run ANY air compressor without a pressure switch??
>> > Thats just asking for trouble, don't do it. The over pressure valve is
>> not
>> > designed for multiple cycles!
>> > Even manual mode should just enable the pressure switch, not over ride
>> it.
>> > Better than wire less air, MicroLevels RF remote allows individual
>> height
>> > control of both sides, so you can tilt the coach for
>> > dumping. This even works with the ignition off as MicroLevel wakesup on
>> a
>> > button press, enables the compressor and opens the
>> > valve(s).
>> > Not to mention true height control and campground leveling.
>> > Keith Vasilakes
>> > 75 ex Roylae
>> > MicroLevel<
http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf>
>> > _______________________________________________
>> > GMCnet mailing list
>> > Unsubscribe or Change List Options:
