Alternate,air pump
jerry work
1,108
Looking for suggestions for an air pump to be used for my air tank to power
the ride. Any alternative ideas welcome.
75 Avion
Dean C. Hanson
Fremont, Ca. 94536
I had the 200 psi version of this left over from my 4x4 days:
https://www.amazon.com/VIAIR-150-PSI-High-Flow-Source/dp/B000X9LTXA/ref=sr_1_11?ie=UTF8&qid=1531749561&sr=8-11&keywords=viair+444c
I use it now as my air source for my bags, and airing up kids inflatable
toys, air mattresses, tires, etc. I simply utilize a 12v air valve in the
circuit that used to power the air compressor. LOVE this thing!
-Will
On Mon, Jul 16, 2018 at 9:35 AM Gerald Work via Gmclist <
> Viair if you want to power it with 12vdc or a 1/2 hp Senco nail gun
> compressor if you want to power it via 120vac through a simple inverter.
> Available in big box stores or on line sources such as:
> https://www.tylertool.com/senco-pc1010-1-2-hp-1-gallon-oil-free-hand-carry-compressor/sennpc1010,default,pd.html?ref=pla&zmam=31282435&zmas=47&zmac=723&zmap=sennpc1010&gclid=EAIaIQobChMI39qyrNmj3AIVQr7ACh0S8Q73EAQYAiABEgKqnfD_BwE
> The Senco route gives you a faster action, less expensive air source that
> can be replaced anywhere on the road at any big box store for a bit over
> $100 in a few minutes. It is a bit larger physically, already has an air
> tank, air pressure regulator, and all the plumbing so hooking up the air
> side is running one air line. Hooking up the electric side is just wire in
> an inexpensive modified sine wave inverter as close to your batteries as
> you can do conveniently and run a 3 wire extension cord to wherever the
> Senco is located.
> Put the Senco where it is easy to get to and use a quick disconnect with a
> check valve so you can grab it to inflate tires or anything else around
> your coach.
> I had one of each in our two coaches and both work well.
> Jerry
> Jerry Work
> The Dovetail Joint
> Fine furniture designed & hand crafted
> in the 1907 former Masonic Temple building
> in historic Kerby, OR
> http://jerrywork.com
> Date: Sun, 15 Jul 2018 12:33:49 -0700
> From: "Dean Hanson"
> To:
> Subject: [GMCnet] Alternate air pump
> Message-ID:
> Content-Type: text/plain; charset="us-ascii"
> 75 Avion
> Dean C. Hanson
> Fremont, Ca. 94536
I recently put in a Viair 480C and a 2.5 gallon viair tank. The compressor fits in the OEM aluminum box and the tank fits nicely under the driver
side lower bunk with a water trap in between. (Royale Rear bath).
Had enough ports on the tank to install a new pressure switch with built in relay, and gauge, safety valve, drain valve, and a quick disconnect for
an air hose. Can do Bags, tires, mattresses, blow gun etc. All neatly tucked away.
The new compressor fills the empty tank and shuts down in about a minute (100PSI). Very happy with the set up. Thanks to Justin Brady for the aux
larger tank idea.
Also ran the power wire direct from the onan battery in the rear to reduce the voltage drop.
Mid Michigan
I also run a 480C and a 2.5 Gal tank. Works great.
I run mine at 160psi, makes inflating tires and air bags faster.
I've got a quick connect on the tank and a 50ft coil hose for filling tires or inflatables etc. It will even run my impact for changing tires if
you're patient.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
If you want air bag controls and a vi-air 480 compressor that you can use
for inflation purposes too, you might consider my wireless remote system.
> you're patient.
> Justin Brady
> 1976 Palm Beach 455
Just as another example of what one CAN do:
My 12 VDC air system runs a Puma compressor (apparently NLA - similar to
Viair 480C). It performs very nicely for normal operations.
Since I always lower the rear suspension when dumping the holding tanks, to
expedite the process, I wanted faster return to ride height. I had an old
Craftsman 120 vac "bowling bag" compressor. When I disassembled what I'd
always figured was a diaphragm compressor, I found a nice little piston
compressor. To make it fit available space behind the refrigerator (my 23'
requires careful space planning), I repackaged it in a custom Lexan box.
It's equipped with a quick disconnect and toggle switch for tires, etc.
Its main control, however, is a "Raise" push button beside the controls for
my two macerators (black & grey water). Also located there are independent
momentary "Lower" switches for the left and right air bags, so I can tilt
the coach to fit the terrain. After dumping, pushing the "Raise" button
routes the compressor output, through check valves, directly into both air
bags. Full down to full up takes about 30 seconds. I do have to have
either the 1500W inverter or the generator running, of course.
Americus, GA
www.gmcwipersetc.com
I like the idea of putting lowering switches at the macerator plate, that's clever! I may "borrow" that idea.
I lower before dumping and then have my wife switch to auto while I'm putting up the hose to get to ride height. With the 160psi and the 2.5 gal tank
it takes under 30 sec to refill and be on the way.
Justin Brady
1976 Palm Beach 455
We run dual 480C compressors. They each have an AUTO-OFF-MANUAL ON switch. Runnning both does the job quickly. Along with the compressors I have an
auxilary air system that has quick disconnect outlets under the hood and in each rear compartment. Also one in the closet. This auxilary system has
a shutoff valve.
Note: if you hear a real loud repeating momentary SCREECH it means you have a compressor switch ON. The screech is the pressure relief valve. Don't
ask how I know.
Steve Southworth
Palmyra WI
On my wireless system, there is a remote control that you can carry in your
pocket. It has 2 preset buttons. One for correct ride height, and one for
dump height. A simple push of the thumb, and you are all set.
> tank
> Justin Brady
> 1976 Palm Beach 455
One word of caution on the Vi-Air compressors. They are capable of 200 psi.
That is quite a bit more pressure than the GMC stock systems put out. You
should probably limit the output with a pop off valve set near the OEM
upper limit. 40 year old air systems could easily be over stressed with too
much pressure.
> your pocket. It has 2 preset buttons. One for correct ride height, and one
> for dump height. A simple push of the thumb, and you are all set.
> Salem, Or
>> tank
>> Justin Brady
>> 1976 Palm Beach 455
At 200 PSI the leak out to be loud enough to find :) When I put the ViAir on the 23' I kept the original shutoff switch for just that reason.
> tank it takes under 30 sec to refill and be on the way.
Justin,
If you think you like KenH's idea now, wait until you get to examine his execution of same.
Justin,
I probably should have included a parenthetical location of the macerator
and level control switches (behind a '70's GM car flip-down license plate
holder). This photo shows the original installation to only control one
macerator; it's since been upgraded to the other 5 switches:
http://www.gmcmhphotos.com/photos/birchaven-macerator/p364.html
VERY convenient location.
Very Cool Ken!
Mine is mounted in the genset compartment.
http://www.thegmcrv.com/wp-content/uploads/2018/07/IMG_20180603_191039-1012x759.jpg
No picture of it mounted yet.
> Justin,
> Ken H.
Justin Brady
1976 Palm Beach 455
One thing you ALL better consider:
If the GMC shops are not familier with what you put on the coach, the next
customer will be upset when we tell them were not familier and will need to
charge them to obtain information.
It is a free country, but putting unknown items on the coach is
inconsiderate.
> Very Cool Ken!
> > Justin,
> > Ken H.
> Justin Brady
> 1976 Palm Beach 455
Why would you EVER run ANY air compressor without a pressure switch??
Thats just asking for trouble, don't do it. The over pressure valve is not designed for multiple cycles!
Even manual mode should just enable the pressure switch, not over ride it.
Better than wire less air, MicroLevels RF remote allows individual height control of both sides, so you can tilt the coach for dumping. This even works with the ignition off as MicroLevel wakesup on a button press, enables the compressor and opens the valve(s).
Not to mention true height control and campground leveling.
Keith Vasilakes
75 ex Roylae
MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Sent: Tuesday, July 17, 2018 9:54 AM
Subject: Re: [GMCnet] Alternate,air pump
much pressure.
> Salem, Or
>> tank
>> Justin Brady
>> 1976 Palm Beach 455
The wireless air system ALSO allows for side to side leveling, as well as
front to rear. With the added feature of one touch return to pre-set ride
height when through with campsite leveling or tank dumping chores. Just for
clarification.
Salem, Or.
> Keith Vasilakes
> 75 ex Roylae
> MicroLevel<
> http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf>
> From: Gmclist on behalf of James Hupy <
> jamesh1296>
> To: gmclist
> much pressure.
> Salem, Or
> one
> > Jim Hupy
> > Salem, Or
> gal
> >> tank
> >> Justin Brady
> >> 1976 Palm Beach 455
> >> GMCnet mailing list
Keith,
To me the MOST important thing about the MicroLevel system is that it works like the OEM system and controls ride height through
sensors that adjust the attitude of the coach as you go down the road. If you are on a road that is highly crowned it will raise the
curb side automatically with no input from the driver just like the OEM system.
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Keith V
Sent: Wednesday, July 18, 2018 8:52 AM
valve(s).
Keith Vasilakes
75 ex Roylae
Rob, the OEM systems ride height is ( are) controlled in two ways.
1. The original early system was entirely operated by air pressure
and left and right hydraulic/pneumatic height control valves that sensed
movement of the frame height when the load in the coach either increased or
decreased. That moved the linkage attached to the height control valves.
Built into the valves was a time delay of up to 18 seconds before any air
was let into the air bag or out of it. In addition, there was a null space
of + or- 3/8" where the frame could move up or down without anything
happening. That is a dead space of 3/4" in the center of the travel. Small
road shocks of a duration of less than 18 seconds never activate this
system.
2. The second generation of height control used the same height
control valves, and had the same operating parameters as the one I
described above. Differences in these two systems were that rocker switches
replaced the original round knob air valves in the dash, and added
solenoids with valves to control the inlet and exhaust of air to the height
control valves. Same null space and time delay as the original system.
3. Finally, the Electro Level II system came out. Totally electric in
control of ride height. Used LED light sources aligned with photo
transistors to open and close electrical circuits that either opened
exhaust valves or started smaller compressors to raise or lower the coach.
Manual controls in the form of rocker switches allows the operator to raise
or lower the coach as required. The null point is narrowed to 5° of travel,
and the time delay is lengthened to a max of 28 seconds before anything
happens. Shutter wheels attached to linkage either block the led's or
expose them to the photo transistors.
Small road shocks, swales of short duration (less than 28 seconds) do
nothing to activate the system. All this information is from GMC manuals,
not from my foggy brain. What does change ride height is inputs from the
driver through the rocker switches, or changes in loads in the coach.
> Keith,
> system.
> Regards,
> Rob M.
> Sydney, Australia
> V
> To: gmclist
> valve(s).
> Keith Vasilakes
> 75 ex Roylae
> MicroLevel<
Jim,
Was I incorrect when I stated "works like the OEM system and controls ride height through sensors that adjust the attitude of the coach as you go down the road. If you are on a road that is highly crowned it will raise the curb side automatically with no input from the driver?"
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Hupy
Sent: Wednesday, July 18, 2018 7:34 PM
system.
> Keith,
> system.
> Regards,
> Rob M.
> Sydney, Australia
> V
> To: gmclist
> valve(s).
> Keith Vasilakes
> 75 ex Roylae
> MicroLevel<
