All bearings are not equal...
homebase1
476
GMCers
Don't take this the wrong way, I'm not trying to start
something...this time :-)
I'm looking at a build up of almost 200 messages and I can't be
sure of who said what, but someone said
My question is: How do we know this to be fact ? If Timken has
ABC printed on a bearing, who do we know at Timpken that has
told us that Cinnibar gets good ones and Mikey's Bearing Shop
gets an inferior bearing. Don't throw things, guys, just askin' .
MikeBeaton
NS
Mike the axial clearance of the bearing is marked on the spacer that fits
between the two bearings. It should read .095" of clearance, and will be
hand written since it is measured for each specific set of bearings.For this
reason, do not mix up the bearings pieces (outer bearing set, spacer, adn
inner bearing set)anything less is to tight unless you know how to calculate
or measure the axial clearance AFTER you press the bearings on the hub AND
insert it in the knuckle.
Why is that important you ask. Good question. The outside of the hub
should measure from 2.0015" to 2.0020". The inside diameter of the bearing
that I have, measures 1.970". If I were to press that bearing on a hub with
maximum outside dimension of 2.0020" there would be a.032" interference fit.
Thats pretty tight and would reduce the axial clearance of the bearing by
some amount. How much? I don't really know, however the cinnabar engineers
have run tests on the various bearings with maximum and minimum dimensions
for both the hub, knuckle and bearing and decided that in the worst case of
each, an axial clearance of .095" is the minimum clearance that can be
safely used.
bottom line. I thrust their engineering expertise and chose to follow their
recommendations. If you have the expertise to measure each dimension (hub,
knuckle, each bearing, and know how to calculate the interference bearings
fit that results from different dimensions, go for it. I don't have the
time yet.
>GMCers
>they may have the same number or look the same. >>>
>MikeBeaton
>NS
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
"The beautiful Mohawk Vally"
Arch it should be a simple thing to check the decrease in axial clearance
due to differenct dimensions of the hub, knuckle and bearings. But for $70
a set is it really worth our time. With a good puller so one can take the
bearings apart for inspection, and re-grease them, a good set of bearing
should last a long time.
>Mike
>I agree with you. I have sent Timken several e-mails asking them the
>same question. I have yet to receive a reply. I bought mine at NAPA.
>So if you see me down some where you will know I was wrong. After
>the last round of bearing mail I went to a place about 20 miles from here
>that is called Bearing Services. The only thing they sell is bearings and
>seals. They say LeSharos need "special bearings"----well NAPA did not
>have them so I bought them from Bearing Services------for 1/4 the price--
>that was 47,000 miles ago. Bearing Services has been in business for
>a long time---they supply all the coal mines around here. I took them
>some of my e-mail and an article for them to read. First they looked
>for what they called a "variant bearing listing". Seems that there are
>some bearings that do get matched to special problems----none here.
>They also told me that if a manufacture were to start a practice of
>"skimming the cream off" there would be He** to pay within the industry.
>They did tell me that there was sever quality control problems in the 70s
>and early 80s. They also thought that these problems have been solved.
>I will also add at this point that my local tire and wheel dealer told me
>that GMC and others went to center hub load carrying wheels because
>they could not get suppliers to hold close enough tolerances on lug spacing.
>I am not recommending that any of you do what I did. I did my research
>and feel comfortable with what I did. I may well be sorry---so be it.
>There will only be me riding in my coach. I have a real problem paying
>extra for something that is better because someone says so and I
>cant verify it. Yes, I have been burnt while doing this whole project
>dont plan for it to happen to many more times. Thats me not you.
>Take Care
>Arch 76 GB IL
>In a message dated 5/7/99 8:08:48 PM Central Daylight Time,
>> MikeBeaton
>> NS
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
not so fast Arch, academia is under the microscope. You are jumping to
conclusions before you have evaluated the facts. Fact not fiction should be
the deciding factor. Are you guilty of perpetuating the myth or are you
going to be a dragon slayer?
Inspect the Timken bearings that you get at your local bearing dealer. Have
they got a tolerance hand scribed on the bearing spacer?
Why would timken and Cinnabar go to this trouble if they were not in fact
different? Common sense rules here, as well as seeking of the truth!
Get the June 1996 issue of the GMc Motorhome news and read the article about
bearings. Than to blow the myth that Timken bearings are all the same, get
General Motors Service parts operations (GMSPO) march 22, 19921 parts and
accessories Action Bulletin No. 91-8. Cinnabar did their homework on this one!
Time to give up
>Tom
>I could agree with you--------but how do you know that Cinnabar bearings
>are any different from NAPA. Same Box Same Numbers. Only Cinnabar
>knows for sure. This is my problem and I know it--------cant find anybody
>to back up their claim. When that happens I run the other way. If
>Timken had said they get out best I would gladly pay. My local dealer
>says no way Hose'. When I do research I want to have at least 3 points
>to try to find out what is true. Right now all I have is one point----the one
>that sells the high price bearing. We will just have to agree to disagree.
>Take Care
>Arch 76 GB IL
>In a message dated 5/7/99 9:29:22 PM Central Daylight Time, warner
>writes:
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
It isn't a question of better or worse bearings. The GMC bearing has a
different amount of axial clearance than the "run of the mill" bearings. We
had a discussion about this last month. Mt bearings came in a box from
Cinnabar. No special markings on the outside. I was told by someone on this
list that their bearings came with an etched clearance number. If that's
what Timken's doing now, you cna tell by looking for an etched number on
the bearings themselves.
Cinnabar says that they get the right bearing form Timken regardless - so
that may be the best solution. I buy the bearings from Cinnabar and don't
try to save money on that part.
That's what I do. YMMV.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
I might be able to shed a little light on this subject from a little
different perspective. I used to work at a place that built carnival
rides. One of the rides was a coaster of sorts. It used about 300 5"
diameter nylon wheels to support the passenger tubs and inertia ring
between the rails. We used matched sets of Timkin bearings in each wheel.
They came in sets that included the specially ground spacer ring packaged
with the two outside races and roller cage/inside race assy.
When putting together that many bearing sets, it's not econimical to take
the time required (even if you can find hired help that will pay close
enough attention) to set the bearing end play correctly. Besides, it's
hard to know when they're set right when you've only got 5" to work with,
unlike a 16" wheel and tire.
We tightened those bearings down with a 1/2" air impact wrench a the rate
of around 3 or 4 per minute. Tight as it would go then on to the closest
slot on the castle nut. The secret to this is that little spacer ring.
The bearings were a common one and could be had for much cheaper than what
we were paying. We were paying extra for the fact that the bearings had
been double checked on the bench and the spacer was within a closer
tolerance than what was ordinarily available off the shelf. This extra
time and labor costs money.
It's comparable to silicone chips. The first run chips are reletively
inexpensive. They might be used in the $5 watches at WalMart. There's
millions of em. The second run chips, the ones that have passed additional
tests, might be used in Rolex's. The next run that have passed even more
exhaustive tests, might be good enough for life support equipment. etc..
It just depends how much manpower has been expended on what started out as
the same raw material.
I imagine the bearings are the same at NAPA as they are at Cinnibar. The
difference, I'd expect, would be in the garrantee that the bearing 'set'
would be the one within the tolerance specified for our GMC's.
It's really all in that little round steel spacer.
Wow, I can't believe I wrote all that!
g'night
bdub
>Tom
>Take Care
>Arch 76 GB IL
>writes:
Regarding "All bearings are not equal..."
WOW----you would like me to just roll over and play
dead----sorry
cant do that. I dont know if you are right or not------but I am
an old
hippy so I will stand and fight. Sorry this had to happen but I
will
not just bow to authority.Take CareArch
Arch
And This old ex-hippy - (now white haired Engineer would be
proud to stand next to you !!!!!!!!!
Pete Papas-Daytona Beach--Land of Hard Beaches & Soft Women
. ___________ (MY TOYS) ___________ (904)672-0571
. /_][__][] []| 1973 GMC M/H /_][__][][] | 1976 GMC M/H
. *O-------OO-/ Painted Desert *O-------OO-/ Royale R/Bath
.1976 Bi-Centennial Iron Head Harley Davidson Motor Cycle
.1979 280ZX Datsun (First Production Year - 1 of only 1000)
.Home Page> http://members.tripod.com/~mehawk_ii/index.html
Do You Yahoo!?
Arch you could not have been a hippy! "Flower Power", "make love not war"
those were the cries of the 60's. hippies didn't fight they made love!
Guys this is getting worse fast. The misinformation is mounting up and will
get some poor sole in trouble if they take them as gospel. In the case of
wheel bearings, if you want to get stranded somewhere with seized
bearings,spend a lot of money correcting the effects of an improperly
selected and installed bearing, you stand a good chance if you follow some
of this advice. Bearings are a pretty exact science and the correct
information is available if you want it. =20
Why are we arguing over bearing information that is substantiated by good
old common sense fact? If you use the correct bearing and install it
correctly you will not have a problem, period. Are you worried about saving
a couple of dollars here? =20
Arch when I used the word academia it was used in the context that all of us
are learned(I have a few degrees also) to some degree and are semi-literate
in the proper maintenance procedures for the GMC motorhome. Usually when we
discuss a subject, many, many put in their two cents worth, and eventually
we arrive by a system of bantering back and forth a meeting of the minds as
to the correct, safe, cost effective method or part to use in keeping our
coaches on the road and out of the shop.
In the case of wheel bearings, opinions are worthless and can be down right
dangerous, unless they are backed up by fact. We are not being fair to our
other netters when we put forth information that is either unsubstantiated
or just plain untrue. Timken has done a tremendous amount of research and
produces a bearing that will run for a very long time maintenance free, IF
YOU INSTALL THE CORRECT BEARING IN THE CORRECT MANNER!
One more time: the Timken bearing that you buy in your parts store is not
the same bearing that Cinnabar sells. Cinnabars part number 12351677 is a
timken bearing with .095" of unassembeled axial clearance. They have been
specifically selected by Timken and assembled for use in the GMC motorhome.
Can you buy a bearing like this at the parts store. Maybe, if by chance you
got one with .095" of clearance. I went through this and tried at my local
parts store and after 10 sets of bearings gave up.
Want to convince youself? Install two different bearing sets on your hub
(off the vehicle of course), install a half shaft, washer and nut and torque
it to 140 ft lbs and than measure the axial clearance of the two sets. You
will probably out of 10 sets not get any two with the same readings.
An opinion that can get you in trouble fast:
1. "If I had to do a GMC with off-the-shelf bearings, I'd be tempted to use
the old shims if still in good shape.
Please. You can't use a shim from one bearing set with another set of
bearings unless you know how to measure the axial clearances AND extrapolate
to the installed clearance when taking into account YOUR COACHES hub and
knuckle dimensions. To use a shim from one bearing with another set is just
plain dangerous.
I have included some information from the Timken Company site:
WARNING!
Never spin a bearing with compressed air. The force of the compressed air
may cause the rollers to be expelled with great velocity, creating a risk of
serious bodily harm.
Proper bearing maintenance and handling practices are critical. Failure to
follow installation instructions and failure to maintain proper lubrication
can result in equipment failure, creating a risk of serious bodily harm.
If a hammer and mild steel bar are used for bearing removal, fragments from
the hammer, bar or the bearing can be released with sufficient velocity to
create a risk of serious bodily injury including damage to your eyes.
=A0=20
Bearing Maintenance Frequently Asked Questions=20
Proper maintenance procedures are essential for achieving maximum bearing
life and performance. Regardless of the bearing type, application or
operating conditions, regular maintenance schedules should be established
and rigorously kept.=20
Bearing and equipment manufacturers work together to specify the techniques
and frequency of removing, inspecting, cleaning, lubricating, reinstalling
and adjusting bearings, along with the type and amount of lubricant needed.
These recommendations are important when scheduling and setting guidelines
for periodical bearing check-ups.=20
Following are answers to some commonly asked questions about bearing
maintenance. We hope these tips will help you gain optimum performance and
long life from your bearings.=20
Q: What do all the prefixes and suffixes on a Timken=AE bearing mean?=20
A: Even the most common Timken bearing has dozens of variations. The letters
in its prefix normally designate the duty class of the series, and the
letters in its suffix designate a type of external modification from the
basic part number. For example, an "M" prefix on a cup or cone part number
designates a medium series. Another example is the commonly used "CD"
suffix, which designates a double cup with groove and oil holes, one of
which is counter-bored for a locking pin. An explanation of all Timken
bearing symbols is included in The Timken Company Bearing Dimension Guide,
which is available from your local Timken distributor.=20
Q: What can I do with cones that won't come off, even with a bearing puller?=
=20
A: Sometimes it is practical to carefully pour heated oil on the cone at the
same time you=92re applying pressure through a puller. The heat will expand
the bearing cone and make it easier to get off.=20
Q: I need to replace a double-row spacer bearing. Can I just replace the two
single cones to avoid the expense of replacing the entire bearing?=20
A: Absolutely not. The parts must be assembled as a unit and not mixed or
interchanged with parts from other assemblies. Spacer bearings are supplied
as complete assemblies. Cone spacers control bearing internal clearance.=20
Q: Can large-bore bearings for industrial applications be repaired?=20
A: The Timken Company has a Bearing Repair and Service Center for large-bore
tapered roller bearings. Repair capability ranges as high as 84-inches
outside diameter (OD) and 19,000 pounds. While reconditioning is not always
the best alternative, bearings can often be returned to original
specifications, including the same warranty, for less time and money than
purchasing a new bearing.=20
Q: When it comes to greasing bearings, is more better?=20
A: The more-is-better philosophy is a common misconception about greasing
bearings. It=92s like taking 10 aspirins for a headache. Follow the specific
guidelines provided in literature published by The Timken Company, and
always follow manufacturers=92 recommendations. These will help you=
lubricate
just the right way... and with just the right amount. Too much grease in the
bearings and housing will cause excess churning of the grease and will
result in extremely high temperatures.=20
Q: Should I use a micrometer to measure the shaft and housing every time I
replace a bearing?=20
A: Absolutely. A bearing is no better than the housing it is mounted in or
the shaft it is mounted on. Verifying that cone seats and housing bores are
the right size is a good long-term investment. Be sure all measurements meet
the manufacturer=92s specifications.=20
Q: When mounting a Timken bearing, should heat be applied?=20
A: You should never heat a standard Timken bearing more than 300 degrees
Fahrenheit, and precision bearings should never be heated more than 150
degrees Fahrenheit. Also, there is a tendency for the hot cone to pull away
from the cold shoulder during installation. After the cone has cooled, be
sure to check with a 0.002" feeler gauge to see that it is snug against the
shoulder where it belongs.=20
=20
>> would be the one within the tolerance specified for our GMC's. =20
>> =20
>Rushing in where angels fear to tread.....
> I think Billy's got something here. I do not believe that Cinnabar's=20
>Timkens can carry any more weight than NAPA's, and I seriously doubt they=
are=20
>the "pick of the crop" at Timken.
> OTOH, what I can believe is that the selection and packaging of just the=
=20
>right spacer is what sets Cinnabar's bearing SETS apart. Since we (of=20
>necessity) run with firmly tightened front axle nuts, that spacer must be=
=20
>thick enough to ensure the bearings are not too tight, (nor too loose).
> Just to complicate things, I recall that some Japanese front-wheel-drive=
=20
>cars used the same system of roller bearings and shims. Mercifully, I=
rarely=20
>had to replace any like that, as the shop manual gave a long arduous=20
>procedure of assembling with a dummy spacer, measuring the preload torque=
of=20
>the bearing, then selecting the right spacer. Never heard of anyone=
actually=20
>doing all that. IIRC, the shim selection was as much to compensate for=20
>variations in the steering knuckle as in the bearings. If I had to do a=
GMC=20
>with off-the-shelf bearings, I'd be tempted to use the old shims if still=
in=20
>good shape.
> In closing may I say I'll buy my Cloyes timing chain from J.C.Whitney or=
=20
>whomever, but for now at least I'll go to Cinnabar for front wheel bearing=
=20
>sets.
>Rick Staples
>'75 Eleganza
>Louisville, CO
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
I think all of us have to have some "hippy" in us to be driving and
working on these ladies.
I've read all the recent comments to date on bearings. I was starting
to sweat because of the heat. I sure hope no one is taking this too
seriously!
All these differences of opinion is what makes this such a great place for
information. Great information if used properly. I know I am going
to think long and hard about where I buy my next set of bearings.
It would seem that if you really know what you are doing, then you
can get bearings from "Big Al's Bearings Outlet" or similar source
and be OK. Otherwise, if in doubt of your own skills etc. go with
Cinnabar.
Keep these lively messages coming in!
Richard Waters '76, PB, Troy, MI
> In a message dated 5/8/99 7:59:09 AM Central Daylight Time, warner
> Tom
> Guess I was the wrong kind of hippy too. Still have the scars from where
> the dogs got me at the 68 Democratic Convention.
> Arch
Not at all Arch, a hippy was a hippy. Its what makes life so interesting,
all of the different folks with differing ideas and experiences. Makes one
want to get in the GMC and tour. So many things to do and so little time.
Remember when some women in the 60's were called dogs also Arch. If that
was what you were referring to at the Democratic convention than I can relate.
Hope you realize Arch that all of the posts are made in the spirit of
commraderie and enlightenment of knowledge in our GMCs. Nothing personal
and certainly not condeming of anyones way to do things.
Peace.
>writes:
>Tom
>Arch
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
We are jocking around Arch like two elephants trying to mate. When one does
research one should read all of the text.
Read the front cover of the parts Interchange Index for this disclaimer:
'The numbers of this index have been communciated by the membership at large
and may in fact contain errors or incorrect applications. It is imperative
that each member use their own resources to evaluate the merit of each item
that is listed in this index."
bottom line Arch. The interchange index contains the same opinions and
incomplete research that is sometimes displayed by all of us, present
company included. One person luckied out and got it to work in his coach so
thinks that everyone can do the same. Sometimes we can. It is only thru the
exchange and experience of many persons that actively work on their coaches
and provide professional support to them, can we hope to arrive at the
truth. We all work for the common good.
My opinion in your case. You were lucky if you picked a bearing off the
shelf and it works for any length of time.You have a better chance of
ruining your hub and knuckle.
>writes:
>Tom
>FACT: I have gone out and dug out my GMC Motorhome International
>Newsletter-------Parts Interchange Index. Under Front Wheel Bearings
>it lists
>Bower/BCA--------------------------- A-23
>CR -------------------------------------- BR-23
>J.C. Whitney------------------------- 38-0649-P
>New Departure---------------------- S-77
>Timken--------------------------------- 23
>NAPA---------------------------------- Set-23
>Federal-------------------------------- A-23
>No opinion given. Just the facts as compiled by the largest GMC club
>I know of. I like choices. Must admit I did not use the cheapest but
>went with a bearing I have had good luck with in the past---Timken.
>Take Care
>Arch 76 GB IL
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Arch,
One thing I have to throw into the bearing discussion is that the
clearance of the "correct" GMC bearings takes into account the absolute
worst case tolerances interference fit of the parts. What if a GMCer has
the absolute least amount of interference fit due to being on the reverse
side of the tolerances? It seems to me that a bearing with less axial
clearance would provide that GMCer with a better, more suitable, fit.
Maybe the one with more clearance will work, but not as good as it could.
Please note that we buy our bearings from Cinnabar and consider it worth
the extra to ensure that we are getting that will work acceptably no matter
what. I'm just wondering if there is an ideal axial clearance that might
provide better than acceptable performance, and if this ideal clearance (or
at least something closer to it) could be determined from measuring the
parts and seeing which sides of the tolerances we are on.
Just some more thoughts,
Zak
>GMCers
>Thanks for a wonderful day I really think we got something done
>today. It looks like I might be wrong in my approach. This actually
>makes me feel good. I think we shook this tree hard enough to get
>all of the fruit out of it. Henry letter to me put all of the pieces
together.
>I have ask for his permission to reprint it here. So dont throw rocks
>at him since it was meant for me. My problem had two parts: Wes
>said in his article that he got the cream of the crop. Timken told me
>they would never do that. Henrys version makes sense to me. I
>personally feel like we are a lot closer to the truth than we were this
>morning. GOOD JOB Henry and all of you who helped.
>Arch,
>here's what I've discovered about Timken and the GMC bearings:
>Timken confirmed that they often select bearings for special
>characteristics for specific customers. These bearings are shipped in the
>SAME original box, but the bearings themselves have the selection criteria
>etched on them - where possible.
>When I talked to Wes, he was dissappointed that Timken would not assign a
>new number to the special selection for exactly the reasons that have the
>discussion happening on our list. Namely, if you order from Timken you
>won't necessarily get the special selection.
>In response to my call, Timken said that the bearings that Cinnabar
>"probably gets - but we can't confirm because we can't reveal customer
>names or specifications" would be a custom selection of a standard bearing.
>One tech rep told me that they do select combinations of spacers and
>bearings to make special clearances etc for customers.
>Wes says that they get a special selection. Timken says that they do make
>special sets for many customers, but won't identify the customers or
>parameters.
>I'm a bit frustrated by the difficulty in finding someone at Timken who can
>definately tell me that the GMC bearings have a specific spacer
>combination. The hub tolerances reported by Wes confirm to me that the
>special selection is required as a general rule. YMMV. Timken says that the
>engineering analysis is up to their customers - they sell bearings only.
>Finally, for what it's worth - my new Timken bearings came in factory
>original packaging with the axial clearance indicated. The box STILL has
>the base product number.
>And that's all I know so far. I think that I'll give up on this one. I want
>to spend time getting Timken to help me figure out how to monitor the
>bearings while I'm driving - for the heck of it.
>Best,
>Henry
>Take Care
>Arch 76 GB IL
Arch you need to take the blinders off. You seem to be arguing for arguments
sake!=20
The point is that the Timken bearing that Cinnabar and Gateway sells has a
DIFFERENT PART NUMBER THAN THE ONES YOU LISTED FROM THE INTERCHANGE LIST.
If you go to the parts store and bought 10 sets of Timken bearings, maybe,
just maybe, one set would work properly in the GMC. But if it did, it would
be strictly by accident.=20
I once had a mathematics professor in college that had a cigar box on his
desk and inside the cigar box was a dissassembled watch(we didn't know what
it was at first). Each day coming into class he would reach for the box,
pick it up and shake it. Finally some brave soul asked him what he was doing
(in those days everyone thought that professors were infallible). The
professor remarked that the box contained a watch in pieces. Of course the
brave student was confused, and asked why he shaked it each day( of course
playing right into the professors hand). The professor remarked that the
law of averages dictated that if he did that every day, sooner or later all
of the parts would fall into place and the watch would be usable again.
In my opinion Arch, you have about as much chance of servicing your front
wheel bearings using the method you described, as the college professor had
of reassembling the watch by shaking the box.=20
If you want to service YOUR wheel bearings as you describe do so, and you
will, by doing so, contribute to the myth that the GMC motorhomes front
wheel bearings are poorly designed, don't work right, and regularly fail.
And next year owners of the GMC motorhomes and you, will say "wonder why"?
General Motors has told us how to do it right. Hope everyone else takes the
advice, follows the Cinnabar method and enjoys long life for their bearings
as a result.
Just the opinion of one person.
Peace.
>Taken from Timken's Home page
>The Timken Company offers a broad size range of bearings from those so=
small=20
>a microscope is needed for inspection to those large enough to stand=
inside.=20
>They weigh from half an ounce to nine tons.
>Timken=AE bearings and components are completely interchangeable and=
consistent=20
>in quality regardless of where in the world they are manufactured or sold.
>Take Care
>Arch
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Arch or Henry what is the part number on your box?
>GMCers
>all of the fruit out of it. Henry letter to me put all of the pieces together.
>Arch,
>parameters.
>Best,
>Henry
>Take Care
>Arch 76 GB IL
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Zack bottom line is that the GMC needs a minimum of .003" of ASSEMBLED axial
clearance to run safely. That means after the bearings has been greased,
pressed on the hub, fitted into the knuckle, and the axel shaft torqued to
from 140-240 ft lbs. since the axial clearance is reduced almost entirely
by the press fit of the bearing on the hub, one could check the assembled
axial clearance for any bearing and hub like I previously described.
>Arch,
>Zak
>>GMCers
>together.
>>Arch,
>>parameters.
>>Best,
>>Henry
>>Take Care
>>Arch 76 GB IL
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Arch I blew it again. I did not read the to line when I sent what I thought
was a private message to you. Dave Greenberg just made me aware of the
stupidity of my mistake. Hope you forgive me.
Still your fellow GMC lover and 1960's associate, and one with more college
degrees than brains.
Tom
>Tom
>Let it be. I have admitted I may be wrong. Henry is the hero here. He did more
>research. But then when I did my bearings there were not that many people
>here. I did not know what Henry has just told me. Thats the beauty of what we
>have here. We can all learn.
>I must admit that I am a little sick and tired of you portraying me as the
>Idiot professor. The stupid hippy. My scars are from a dog that was not a
>lady.
>Henry has confirmed that the parts #s are the same not different like
>you say. I still say we got closer to the truth today. I am proud of
>that even if I was wrong.
>Take Care
>Arch
>In a message dated 5/9/99 12:38:01 AM Central Daylight Time, warner
>writes:
>doing
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
