Alignment kit?
Keith V
3,608
407
83
has anyone found an alignment kit that works for the GMC.
Something that does toe, caster and camber?
I know Gerald Work made one a while ago.
I bought one of those kits and didn't like it. Expensive. The turn plates are heavy, the rubber non-skid (CPVC shower plan liner) wouldn't stay glued to the steel bottom plate no matter what glue I used, and the bottom plate would turn instead of just the upper plate. The frame standoffs are commercial retail shelving brackets with magnetic braces screwed on, again didn't like them.
My turn plates consist of layers of heavier plastic trash bags, 2 layers of scrap 1/4" melamine cabinet backs with plastic in between, you can use almost anything.
I use a laser level/pointer on top of a paint can or some such to get the laser line at frame level, measured off the frame front and back and adjusted the laser horizontally until the readings were the same. That's parallel to the frame and there's no string or standoffs to get in the way.
I repurposed a bracket out of scrap that mounts to the wheel and has a vertical flat plate that holds the camber/caster gauge. The 3 all-thread standoffs were measured with a micrometer to be uniform, and the fixed nuts have Loctite so they don't move - only the outermost clamping nut can be loosened so the bracket breaks down for easy storage.
Reactions: RoadTrippin
Here is how I check and do my wheel alignment and can do all 6 wheels. I haven't come up with an easy way to check caster though.
Reactions: boybach
I'll just plant this little tidbit of info here, if you get an inexpensive caster meter online you may find that the meter isn't labeled correctly. Negative caster is labeled Positive and vice versa if you follow the directions. Took me a minute to figure that out
This is the one I bought for $25 on amazon but I see similar ones sold elsewhere, I imagine they are all the same. Drove me nuts!
Perhaps this will save someone some time.
