Thanks for the bag discription Jim....never would have thought that.
> The original bags are three distinct layers. The inside layer is a soft
> neoprene of military specs. The middle is a fabric, not unlike fire hose.
> The outer layer is an extremely tough, durable, u.v. resistant neoprene.
> Also military spec. Why military spec, you might ask.
> Because those bags were developed to support the nuclear blast proof
> buildings inside Cheyenne Mountain. Really good stuff. So, the outer layer
> protects the inner two. The innermost one holds the air. Most of the time,
> when you suspect a bag leak, it is at the end where the air valve is
> located. It is usually a "0" ring that has worked loose or deteriorated.
> Those fittings are a real bugger to loosen, but usually will yield to
> persistent effort. The "0" ring is between two flat surfaces that each have
> a partial groove machined into them. That "0" ring has to seat perfectly
> between those plates, or they will leak. So, bubble test that juncture if
> you suspect the bag is leaking. The bag will need to come out to replace
> the "0" ring. Just what I know.
> Salem, Oregon
> On Sat, Dec 14, 2019, 12:38 PM tonka6cuda6--- via Gmclist <
> >> Our GMC's have alway been under cover when stored for the winter and a
> >> cover to keep the sun off the coach in the summer time.
http://www.gmcmhphotos.com/photos/g3851-rv-cover.html
> >> Since moving to our new place in 2004 I have had a large pole barn to put
> >> all my "STUFF" into.
> >> In all my years of storing the coaches thru the winter season (1998 thru
> >> 2005 & 2018/19) I have alway put blocks un the middle of bogy assemble.
> >> The blocks are 8" tall, The blocks are NOT used to support the coach if
> >> working underneath the coach. I have always stored the coach longterm
> > with
> >> the air out of the system. At this time i clean the air bags with 303
> >> Aerospace Protectant that cleans the air bags and provides UV protection
> >> for the following season.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1311.R1.TR12.TRC2.A0.H2.X303.TRS0&_nkw=303+aerospace+protectant&_sacat=0
> >> This is how I do mine, your procedures may vary!
> >> J.R. Wright
> >> GMC Great Laker
> >> GMCGL Tech Editor
> >> GMC Eastern States
> >> GMCMHI
> >> TZE Zone Restorations
> >> 78 Buskirk Custom 29.5' Stretch
> >> 75 Avion (Under going Frame up Restoration)
> >> On Location in Tucson
> >>> It is not good to have the suspension collapsed without the air in the
> >>> bags. They wrinkle up and a good deal of weight is applied to the
> > wrinkles.
> >>> Better to raise it to ride height or slightly higher than that,
> > then
> >>> block up under the bogie boxes enough that if you lose air, the
> > weight of
> >>> the coach is supported by the blocking.
> >>> If you are a belt and suspenders kinda guy, block the tires
> > entirely
> >>> off the ground as well, and wrap them in such a way as to shield them
> > from
> >>> harmful ultraviolet radiation. (Sunlight) This will prevent flat
> > spots in
> >>> the spring when you wake up the coach from it's long winter nap.
> >>> Here in Oregon, we have rallies year around. So, not much
> >>> weatherization is done. Only for 3 or 4 weeks a year does it even get
> > cold
> >>> enough to worry about frozen pipes, tanks, etc.
> >>> Jim Hupy
> >>> Salem, Oregon
> >>> On Sat, Dec 14, 2019, 10:43 AM John Phillips via Gmclist
> >>>> My vote is to air them all the way up, block the rear end up and let
> > it
> >>>> settle on the blocks.
> >>>> Unless your coach is better than mine you would have to run the
> >>> compressor
> >>>> at least once a week to keep the coach off the ground.
> >>>> I would also block the front end to eliminate weight on the front
> > tires.
> >>>> On Sat, Dec 14, 2019 at 9:47 AM Richard Denney via Gmclist >
> >>>> > Too high and there's risk of hot-dogging, where the bag takes a
> >>> permanent
> >>>> > set in the curved shape. Too low and coach rests its weight on the
> >>> shocks
> >>>> > (which are at full extension).
> >>>> > I rest mine on sections of 4x6x24" pressure-treated lumber made to
> > use
> >>> as
> >>>> > posts for decks. I orient the long side vertically so that the coach
> >>>> rests
> >>>> > higher. I don't put the system on lower--I just let nature take its
> >>>> course.
> >>>> > I've never been able to completely eliminate the leaks.
> >>>> > Rick "who needs to pressure-test the left bag" Denney
> >>>> > On Sat, Dec 14, 2019 at 12:14 PM tonka6cuda6--- via Gmclist >>
> >>>> >> Should one keep the suspension aired up or aired down for the
> > winter
> >>>> > while
> >>>> >> being stored?
> >>>> >> Rich Mondor,
> >>>> >> Brockville, ON
> >>>> >> 77 Hughes 2600
> >>>> >> _______________________________________________
> >>>> >> GMCnet mailing list
> >>>> >> Unsubscribe or Change List Options:
> >>>> > '73 X-Glacier 230 "Jaws"
> >>>> > Northern Virginia
> >>>> > Offlist email: rick at rickdenney dot com
> >>>> > GMCnet mailing list
> >>>> *John Phillips*
> >>>> GMCnet mailing list
> >>> GMCnet mailing list
> >> GMCnet mailing list
> > I used 303 on my leather truck seats and its fantastic stuff.....never
> > thought of using it on the bags....might have to give it a go.
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
Rich Mondor,
Brockville, ON
77 Hughes 2600
