Airbag Fitting
duane m simmons
372
Mike in GB
The Air bag does have a steel fitting that screws into the air bag on the
end where the air line is attached. The Air line fitting is screwed into
this steel fitting. If this is the place where the failure occurred,
then remove the steel fitting & replace with another steel fitting from
an old bag. Also replace the O-Ring that is at the bottom of the steel
fitting.
Duane of Orange CA
