Hi all, Put in new check, Bendix p/n #800375 SC-3 SGL. Pressured Tk. only
from m.t. to 130#, went like this, 65 105 and 130
shut-off, This is the tk. under pass. wheel well. Removed tubing no leak
from check. and no leaks from fittings. 4 hours and tk. still holding 130#
Air bags still up and proud after 8 days. No separator yet the one they had
was a regulator also but 0-125. So still looking for one to install between
pump and check. Guess I need a new pump, If 317 not in by 8-11 Hope Dana
hangs for next trip to take grandkids back to Antioch CA. and watch the
Raiders mount there super bowl charge!!!!
Still got to get Radiator out for repair!!! Or I found a rad. shop that will
flush engine R&R Rad. recore and all that good stuff for $450.00+/- afew. He
said these Rad. cores is usually good for 10yrs. and if close should be
replaced he knew about the cage and front removal. This was Hancock Radiator
in Bullhead city.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
in Bullhead city.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
