J R, I recently replaced the exhaust solenoids and rebuilt
the "hold" solenoids on my EL II system. The cost was about
$160 for parts. The system now holds air for weeks. BTW,
the manual states that the exhaust solenoid will limit air
pressure to 150-180 psi.
Incidentally, as far as I know, all of the hold solenoids
are installed backwards from the factory. Even the manual
is incorrect about their installation. (At least they were
consistent.) The solenoid valve has an arrow on the side of
the body, which should point in the direction that you want
the solenoid to "hold". In our application, we want to
"hold" air in the bag. Therefore, the arrow should point
away from the bag and toward the compressor. If yours are
still in the original configuration, the arrow will be
pointing toward the bag, and you can get a nice improvement
in leak-down by reversing their direction.
Scott Shean
Baton Rouge, LA
78 Royale
>-----Original Message-----
>From: owner-gmcmotorhome
>[mailto
wner-gmcmotorhome]On Behalf Of
>Jrwheeler7
>Sent: Wednesday, September 22, 1999 9:17 AM
>To: gmcmotorhome
>Subject: GMC: Air suspension upgrades
>Scott,
>I failed to mention it in my post, but the upgrade is for
the
>Electro Level
>II for my coach. I have leakdown in about 2 days.
Cinnabar sells
>a kit for
>$350, which eliminates the leakdown due in part to the
aging of
>the system.
>The kit includes a high pressure limit of 120 pounds (there
is no
>high limit
>in the Electrolevel II system; a malfunction in a component
could
>allow the
>pump to raise the pressure to the point that the bag
explodes) and gauges,
>etc. Cinnabar also sells upgrade kits for the Power Level
and Electro I
>systems. Not cheap, but I want the system to operate the
way it
>was designed
>before I put the coach on the market.
>J R Wheeler central NC (glad not to be in Eastern NC).
Scott Shean
Baton Rouge, LA
78 Royale
>[mailto
>Jrwheeler7
>To: gmcmotorhome
>Scott,
the
>Electro Level
Cinnabar sells
>a kit for
aging of
>the system.
is no
>high limit
could
>allow the
and Electro I
way it
>was designed
