So the compressor comes on but does not air up bag. Yes it could be solenoid dirty or bad? You could use VOM to check for voltage going to it.
> The compressor (Viair) is fairly loud so if there is clicking I do not hear
> it.
> On Sat, Sep 21, 2019 at 6:35 PM Charles Boyd via Gmclist <
> > Sir, does the raise side you are having issues with make any clicks or
> > anything in the cabinet when you push the switch to raise? If not It could
> > be
> > the switch dirty, they are fairly easy to take apart and clean with an
> > eraser and lube.
> >> I have one compressor and not an electronic ride height sensor in the
> >> wheel well.
> >>> Do you have one compressor, or two? Do you have electronic ride height
> >>> sensors in the wheel wells?
> >>> Jim Hupy
> >>> Salem, Oregon
> >>> On Sat, Sep 21, 2019, 4:57 PM w schurman via Gmclist
> >>>> I do not know which one but I think that it is Electro=Level II. The
> >>>> controls are to the left of the driver, does this help?
> >>>> On Sat, Sep 21, 2019 at 4:29 PM Matt Colie via Gmclist >
> >>>> > OK, William,
> >>>> > By design, the airsprings (airbags) are supposed to be completely
> >>>> > isolated.
> >>>> > Next question:
> >>>> > Is the coach Electro-Level I or Electro-Level II?? BIG Difference.
> >>>> > If you do not know, tell us what you do know.
> >>>> > Matt
> >>>> >> I can air up the left rear bag without a problem however I cannot
> > air
> >>>> up
> >>>> >> the right rear bag at all. I have been under the belief that the
> > line
> >>>> is
> >>>> >> pinched to the point that air cannot pass through( I cannot get
> > under
> >>>> the
> >>>> >> coach to inspect ).to the bag.
> >>>> >> But could the problem be with the solenoid and if it is how do I
> >>> check
> >>>> it
> >>>> >> Thanks for any advice.
> >>>> >> William S. Schurman
> >>>> > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> >>>> > Electronically Controlled Quiet Engine Cooling Fan
> >>>> > OE Rear Drum Brakes with Applied Control Arms
> >>>> > SE Michigan - Twixt A2 and Detroit
> >>>> > _______________________________________________
> >>>> > GMCnet mailing list
> >>>> > Unsubscribe or Change List Options:
> >>>> William S. Schurman
> >>>> box 772806
> >>>> Steamboat Springs, CO
> >>>> 80477
> >>>> 1978 Palm Beach
> >>>> TZE168V100258
> >>>> GMCnet mailing list
> >>> GMCnet mailing list
> >> William S. Schurman
> >> box 772806
> >> 80477
> >> 1978 Palm Beach
> >> TZE168V100258
> >> GMCnet mailing list
> > C. Boyd
> > 76 Crestmont
> > East Tennessee
> William S. Schurman
> box 772806
> 80477
> 1978 Palm Beach
> TZE168V100258
C. Boyd
76 Crestmont
East Tennessee
