Air pressure 1976 Palm Beach
Samuel are you talking when you first put it into gear and the light comes on? Or other?
Rich Mondor,
Brockville, ON
77 Hughes 2600
I think that light, in your case, is wired to the air pressure start switch. So it will be on any time the comoresser is running or if it fails to
start when the air switch is tripped. That switch off and on levels is adjustable. I have mine set at around 90 and 125 PSI.
Samuel,
The "Low Air" warning light is entirely separate from the compressor, compressor switch, and "set power level to travel" light and buzzer, at least
as GM did it. The "Low Air" light is not all that useful, as the switch controlling it is set rather low. The manual doesn't specify, but I'd guess
it's around 50 or 60 psi, which is too low to get my '75 Eleganza up to ride height.
Because of that, it was recommended many years ago (in the GMCMI newsletter IIRC) to wire the light to the compressor circuit as a "compressor
running" indicator, and that may have been done to your coach, but it's not original. I saw no need to do this as I can usually hear the compressor
when it's running.
If your light stays on after the compressor shuts off, and you have normal 100 - 120 psi pressure, you either have a bad warning light switch (on
the tank I think) or a short to ground in the wiring from the warning light to the switch.
HTH,
Rick Staples
Rick Staples, '75 Eleganza, Johnstown, CO
"Advice is a dangerous gift, even from the Wise to the Wise, and all paths may run ill." -Tolkien
In the earlier coaches you don't need a "compressor running" indicator any more than you need a tach to tell you that they engine is running. A low
pressure indicator (like the kind with a separate switch and circuit as I have planned for a future small project) would be helpful as we one time
took a hit to the air system that left the compressors pumping its dear little heart out and still not making adequate pressure.
